leaking injector??
Old Mar 20, 2014 | 08:28 AM
firedude 159's Avatar
Angry leaking injector??
I just replaced the injectors in my 03 2500, stock unmolested. after idle up for awhile, I noticed a fuel knock and white smoke. shut it down waited about 15 min and restarted, heavy white smoke, still knocking. I drove it up the street and got a moderately heavy fuel knock, white smoke. Could one of them be leaking or a tube leaking. None of this prior to injector change...
2003 dodge 2500 unmolested,274000 miles
Old Mar 20, 2014 | 08:44 AM
soulezoo's Avatar
DTR 1st Sergeant
Don't drive it any further. One of the injectors is bad. Either cracked nozzle or body. That is unlikely to be the crossover tube.
Anyway, it is bad injector juju.
Old Mar 20, 2014 | 09:18 AM
soulezoo ,thanks for the reply. any suggestions on isolating the bad one?
Old Mar 21, 2014 | 09:38 AM
soulezoo's Avatar
DTR 1st Sergeant
A mechanic with a scan tool can shut injectors off and on one at a time to isolate them.
A much harder "poor man's" way of doing it involves (insert danger warning here... do NOT operate an uncapped rail!) disconnecting the injector line (one at a time) from the rail, properly capping the rail and starting the engine to listen for difference in running. When the knock and the white smoke stops, you found the bad one.
Old Mar 21, 2014 | 09:45 AM
BigIron70's Avatar
Cummins Guru
You can also use infrared temp gauge read exhaust temp on each exhaust outlet on manifold the one reading the lowest temp is the bad injector cylinder. Or cap off each injector line at the rail until you find cylinder that is knocking or causing white smoke. First test maybe fastest but do not drive vehicle with injector dumping fuel into cylinder. Also change your oil most likely diluted with diesel fuel now.
Old Mar 27, 2014 | 03:14 PM
HELP!!! started checking injectors for leaking one. checked 2,3 got some smoothing out. caped off no.1, truck wont start at all. I get a fuel knock every so often while cranking, a little white smoke, but no go........
Old Mar 30, 2014 | 10:35 PM
Ok. I re-replaced all 6 injectors. Truck started. Question is, how long will it take to clear up white smoke and engine to smooth out?? Cylinders were loaded with fuel......
03 2500 4x4 unmolested 274,000 mi.
Old Apr 2, 2014 | 10:32 AM
HELP PLEASE!! As last posted, I re-replaced all injectors. White smoke has cleared up, but engine still has a miss. Does ANYBODY have insight??
lilsuzuki4x4
Sep 1, 2011 01:50 AM
Jambbii
Nov 5, 2004 10:59 AM
berner
Mar 7, 2004 09:02 AM
bwat4
Feb 6, 2004 09:32 AM
yomitch
Apr 21, 2003 06:28 PM
