K & N air filter
Old Feb 20, 2005 | 06:08 PM
The Domie's Avatar
K & N air filter
Is anyone using the K & N cone filter and the replacement intake box/tube?
I used a K & N in my 99 ,10 cyl gasser with good results, but I don't want to screw up this Cummuns.
Thanks
The Domie
Old Feb 20, 2005 | 06:52 PM
crobtex's Avatar
There's a lot of discussion on air filters. Do a search and you will probably get more opinions the you can digest.
Old Feb 21, 2005 | 09:53 AM
Texcowboy9's Avatar
General Concenus - Dont use K&N on a CTD.
Old Feb 21, 2005 | 10:39 AM
bhoeffner's Avatar
I'll second that. Look at AFE pro-gard seven instead.
Old Feb 21, 2005 | 10:55 AM
Miles PH's Avatar
Also check out www.Volantperformance.com cool air intakes ram air is what I have and love the throttle response. And yes don't use K&N on your CTD.
Old Feb 21, 2005 | 11:20 AM
Scotty's Avatar
Top's Younger Twin
www.scottysystems.ca www.scottyairsystems.com
Scotty Air II [94-02] and Ram Air 3 [03-current]
Two stage Foam, ppm of Silicon highest report 7PPM, available here in the online store.
Uni is recognized for its use in the BAJA as well as many other off road VERY dusty environments. Also easier to maintain then the cotton gauze.
Scotty
Old Feb 23, 2005 | 09:42 PM
el jefe's Avatar
I had one on my 02 and have have one on my 03 for several months now and don't see a problem. I put around ten thousand on my 02 then gave it to my friend without cleaning it and he put another twenty thousand on it with no problems. I personally think they are o/k.
Old Feb 24, 2005 | 09:36 AM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
I use the K&N FIPK and I like it in my 04.5. The turbo howls now. Used the K&N stock replacement filter in my 99 and liked it also. I put over 100,000 miles through it and it is still going. Dad is driving that truck now with 150,000+ miles. No problems. Just my 2 cents here, but the folks who do not like or have had problems with K&N products probably clean the filters too often. Put it in and leave it for 30-50,000 miles like it says. A slightly dirty filter will filter better than a pristeen clean one no matter who makes the filter!!!
Old Feb 24, 2005 | 09:56 AM
PCarnathan's Avatar
K&N Air Filter
I've had the replacement air box and filter on my '03 for a couple of years. Instant increase in power. It's the easiest, cheapest, best bang-for-the-buck mod you'll make on your truck. Opinions vary, but no one's had to replace a motor due to the use of a K&N filter. I use K&N filters on every internal-combustion motor I own, except my Onan generator. I'd have one on it if I could find one.
Old Feb 27, 2005 | 09:42 AM
Jonesey's Avatar
No per Cummins website. They state the use of oiled filters such as K&N are not recommended. The key word here being recommended. This could possibly void the warranty if engine damage was caused by the use of non approved parts. If you choose to use oiled filters, repeat after me. I am my own warranty station. You will have to determine if any advantage gained out weighs the possibe headaches if you should have a warranty claim. The debate rages on. Personally I just purchase the DC filter and don't have to worry about it.
Old Feb 27, 2005 | 02:53 PM
Tony T.'s Avatar
You might try doing some reserach on the web about the filteration of the K&N and others. I know I have read on the TDR a link to this subject, but do not have it available. My understanding was the paper ones filters better on small particales. For myself I choose to run the stock filter, but If I decide to mod I'll go with a BHAF. JMO
Oil analysis will give you the best results on how your brand of filter is working for your engine.JMO
Tony
Old Feb 27, 2005 | 10:32 PM
kelley15's Avatar
Also make sure any air sucked through the filter is Cummins / D.C approved or they will void your warranty.
49lambert
Jan 17, 2011 04:53 PM
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
