Jake brake vacuum pump
Old Sep 2, 2012 | 11:40 PM
Danavilla's Avatar
[QUOTE=DodgeChallenger;3129565]Folks just to clarify this thread.
The brake units use pressure not vacuum so don't go buying a vacuum pump to operate the butterfly type exhaust brake."
The Jacobs exhaust brake uses a vacuum pump and actuator to operate the brake, not air pressure. I switched to a PacBrake which does use an air compressor. I had a BD brake installed on my '98 that used the factory vacuum pump. Both were butterfly type exhaust brakes as is the PacBrake so some exhaust brakes use vacuum and some use air compressors. Best not to make blanket statements without all the facts.
Old Sep 3, 2012 | 09:22 AM
CoastalDav's Avatar
My PAC valair unit keeps blowing the fuse after about 1/2 hour. Might have to replace it and mount it in the cool air up front somewhere as heat kills electrics.
The Jake (Cummins Exhaust Brake) that is used on the 3500 5.9 Cummins trucks uses a vacuum pump driven up front on the belt drive to activate the brake disc. The Pac Brake uses an air pump and air pressure to activate the brake disc.
Most feel the Pac Brake is a better brake than the Cummins Jake. Only difference is Dodge says if you don't use the Jake, your warranty is voided if you tow heavier than 10,000 lbs. Its also voided if you tow heavier than 10,000 lbs without it.
That does not apply to the 6.7 2007.5 and later.
Dave
Old Jul 1, 2016 | 11:56 AM
Colo_River_Ram's Avatar
With age comes the cage
Originally Posted by edtyler
This is the information from my Rock Auto order:
1999 GMC K2500 PICKUP 6.5L 395cid V8 DIESEL FI Turbo (F) OHV DORMAN 904801 (904-801)Vacuum Pump$ 92.89
Thread revival time folks
Has anybody else tried this pump in lieu of the Jake Brake pump?
Old Jul 8, 2016 | 02:02 PM
Bump!
Lovemydodge06
Jun 22, 2013 07:30 PM
Reelay
Apr 25, 2012 06:51 PM
jarmar
Sep 5, 2010 08:06 AM
mylash
34
Oct 18, 2009 07:14 AM
HaulinRoans
Oct 19, 2006 10:34 AM
