How too disable the grid heaters?
Old Nov 2, 2006 | 07:16 PM
phloop's Avatar
Question How too disable the grid heaters?
Does any one know how too go about doing this? I would like to be able to control when the heaters work and does not. I am thinking of something with a switch so that they will function normally when cold but after the rig is started I can disable them.
Starting to get tired of my truck acting like a strobe light.
Old Nov 2, 2006 | 09:44 PM
BigDave12768's Avatar
Say goodbye to any and all warranties. PLus I think you would do more damage than good.
Old Nov 2, 2006 | 09:56 PM
KBennett's Avatar
I can tell you how to do it but accept no responsibility from any engine damage.
Find the grid heater solenoids. There will be two large wires on each one and some small ones. You need break the circuit on one of the small wires with a toggle switch on each solenoid.
Old Nov 2, 2006 | 11:14 PM
cdru's Avatar
Why would you want to disable them? They will turn off by themselves after a few minutes, or once you get up fifteen-twenty miles per hour. cdru
Old Nov 2, 2006 | 11:51 PM
The problem is he wants to stop his lights from dimming a little. So he would have to put a circut breaker on all the heaters.
Old Nov 3, 2006 | 12:12 AM
B.Law's Avatar
How about for the opposite? Would the truck warm up faster if you could keep them on longer? I always wondered why it turns off at 20mph. Also durning those winter months when you pull over to take a nap and leave the truck running, sure the rpms bumb up, but it would be nice for the grid to cycle every now and then to help keep engine temps up. I don't know how well the batteries and charging system would like all the extra duty though.
Old Nov 3, 2006 | 12:13 PM
DBLR's Avatar
I'm not the sharpest person in the world but how can a grid heater warm up the engine any faster? All a grid heater does is heat up the in comeing air for the truck to start when the temp is somewhere around 58 degrees or so.
Old Nov 5, 2006 | 08:00 AM
B.Law's Avatar
I hear the grids get pretty darn hot, I think any additional heat to the engine woud help out a little. It must get hot since it seems to work as well as glow plugs. I'm mainly looking to keep the head temps up while idling in the winter months.
Old Nov 5, 2006 | 09:38 AM
TopBanana's Avatar
shutting off the grid heaters is easy. kbennett is exactly right, just break the small circuit on the relays with a toggle switch.
turning the heater on longer or whenever u want is easy too. u would have to supply accessory power the close the relays instead of the ecm doing it.
but i don't see why this is really needed or wanted????
Old Mar 11, 2007 | 05:49 PM
wfbmfb's Avatar
Grid heaters 1993 Dodge W350
I looked at this thread to see how other people would disable their grid heaters. What has been said about installing a switch in the relay primary wires is what I was thinking of doing. The reason I want to be able to disable them is because I can't operate the power windows without the key switch in the on (run) position. In the accessory position there is no power to the windows. This is the way the owners manual says it works. (I've never had any other vehicle where the windows wouldn't work in ACC.) I don't want to cycle the heaters just to operate the windows if the engine is not running.
Second reason is I have a Fisher Quick Switch plow mounted in the winter which is electro-hydraulicaly operated. Sometimes I want to move the blade without starting the engine (to get working room around the front of the vehicle). Again, I don't want to have to cycle the heaters just to do this.
I've noticed in some posts people talking about cycling their heaters twice or more for cold starts. My owner's manual says not to cycle them more than once every 15 minutes.
Bill
Old Mar 11, 2007 | 08:38 PM
Forrest Nearing's Avatar
uhh... just disconnect the large gauge wires from the grid heaters that's how mine are
Old Mar 11, 2007 | 11:03 PM
PurNLoud's Avatar
Bill
On the newer trucks on the driverside visor it states that multiple cycles can be done by simply turning to the off position, and back to start, I've been in extremely cold weather and once has always been plenty.
High idle will engage automatically if additional heat is needed to maintain engine temps in cold weather and the newer trucks you can control this at anytime.
Old Mar 18, 2007 | 02:36 PM
KevinT's Avatar
Do the grid heaters go out ontheir own. I have a feeling that mine doesn't work any more. When my truck starts it run rough and smokes. Why would anyone want this on a daily basis. Any help on finding my grid heater problem would be appreciated.
Old Mar 18, 2007 | 08:26 PM
tacohat's Avatar
I think I remember somewhere on here that someone had an instance where the grid heater did not turn off and had the intake side glowing red hot. Anyone else remember seeing that? There should be no problem turning it off when you don't want it to run. But controlling the amount of time it stays on is probably a bad idea.
Old Mar 19, 2007 | 03:55 PM
Lost Lake's Avatar
Maybe you could hook your lights up differently.... put them on their own circuit more or less.....
sootnsmoke
Dec 29, 2011 06:32 AM
92cummisw350le
Oct 26, 2007 07:55 PM
caper
13
Dec 25, 2005 08:40 AM
Hoss
16
Oct 20, 2003 09:13 AM
Cumminsdude
Mar 25, 2003 11:58 AM
