How many quarts oil change 2007 5.9
Old Jan 24, 2009 | 10:24 PM
jbham's Avatar
I just bought a used 07 Quad Cab 2500 6-spd and changed the oil. I took it to Kwik Kar and they said it took 13 quarts. I checked my manual which stated 12 quarts. He filled it with 12 and showed me that the oil level was not in the safe zone on the dip stick. I said ok and said add a 1/2 quart. Do you all have any advice on this?
Thanks
Old Jan 24, 2009 | 10:33 PM
Old Hat's Avatar
12 qts....
Old Jan 24, 2009 | 10:43 PM
hivoltage's Avatar
Good question actually..... I've done a 13 quart change on mine since the first time. I also read somewhere that is what it holds BUT for some reason I was thumbing through the owners manual last time I read 12quarts soooo I done a 12 quart oil change.
I find it hard to get a consistant reading on my stick for some reason? There have been times when it's read on the low end and the next day it'll read normal or even slightly above full. I'm always careful to make sure conditions are the same each time I check the oil level i.e truck level, dip stick seated properly,letters on stick handle upright,etc,etc,etc but I still seem to get different readings from day to day.
Anyway I think that 12 quarts is the proper amount and it's what I'll use from now on. I just wish I could remember where I read 13 quarts?!?!
Old Jan 24, 2009 | 10:51 PM
Little03's Avatar
Three 4Liter jugs or 12Liters.
Old Jan 24, 2009 | 10:53 PM
Shagginwagon's Avatar
12 qts. + the filter!
jbham's Avatar
Thanks Guys.
BEARHUNTER's Avatar
From: Well I thought I lived in America, but its looking more like france every day.
Ive always used 12qts. thats what my owners book says to do.. Ive always been over the full mark on the dip stick but its fine. if it says put 12 qts in, thats what I do.
Old Jan 25, 2009 | 03:47 AM
Spooler's Avatar
Make sure they use Diesel engine rated oil, Cj-4 or CI-4. Delo 400, Shell Rotella T, Valvoline Premium Blue, etc. and yes the manual states 12 quarts or 3 gallons. Also, either use a Fleetguard oil filter or a Mopar oil filter which is a fleetguard filter. If you don't use one of those you are asking for trouble.
Old Jan 25, 2009 | 08:40 AM
xtoyz17's Avatar
Thats not necessarily true. A Mobil1 filter is just as good, and more readily available.
I started reading this because I did my oil last night, put 3 gallons in, and it was at the bottom edge of the safe level. I chocked it up to varying dipstick tubes, dipsticks, and an act of god? I'll just have to make a mental note of where it is on the dipstick so I have a reference point.
Shawn
Old Jan 25, 2009 | 08:42 AM
yellowhemi's Avatar
My 07 5.9 always takes a full 13 quarts with filter, but my 05 would only take 12 quarts with filter. Strange huh?
Old Jan 25, 2009 | 09:06 AM
jbham's Avatar
I think they used Rotella 15w-40. Is that correct ?
Barry
Old Jan 25, 2009 | 09:14 AM
92'1stGen's Avatar
Barry
Yep that's good stuff. 12 qts, including the filter for both of mine.
Old Jan 25, 2009 | 11:07 AM
jbham's Avatar
some of you are saying 12qts with the filter. Does that mean you put 12qts and also fill the filter up and does the filter hold a qt?
Old Jan 25, 2009 | 11:33 AM
SundayMoney's Avatar
I add 12qts. I open a gallon and fill the filter,the rest gets dumped in the engine.
In my truck,12qts is right to the top of the safe zone on the dip stick.
Old Jan 25, 2009 | 04:16 PM
dsl21's Avatar
I have always uses wix filters on my trucks,is ther something dif about a 3d gen so they dont work as well??
