how does high idle work
Old Oct 8, 2004 | 05:20 AM
BPD239's Avatar
It does work on 04.5's with automatic transmissions. I just had this done to my truck.
Old Oct 8, 2004 | 08:21 AM
dwhite's Avatar
While in park and pressing "set".....do you have to press the throttle a little?
Old Oct 8, 2004 | 11:34 AM
GreyTD's Avatar
dwhite
assuming you got it enable from dealer first. Manual high goes like this 1- start truck 2- turn cruise control on 3- press the cruise set button (engine will idle up to about 1100rpm) 4- using the resume/coast button you can increase the rpms up to 1500rpm no need to touch the throttle. If it does not idle up after setting the cruise then you do not have it enable. If you touch or hold the brake it will not work.
Old Oct 8, 2004 | 11:37 AM
cquestad's Avatar
You can't touch either pedal...
Works like a charm...cuts warm up by 10 fold.
Old Oct 8, 2004 | 11:44 AM
GreyTD's Avatar
actually on mine I can increase the rpms with trottle and it won't disenage, but the brake and it's gone
Old Oct 10, 2004 | 09:35 AM
moterhead's Avatar
What I said did not work on the '04.5 is TSB 18-004-04.
Read it yourself here.
http://www.portjeff.net/df5152/tsb_1800404.htm
Here is the original thread discussing this TSB.
https://www.dieseltruckresource.com/...4&pagenumber=1
On the '04.5s you only need to have the dealer use the OBD to enable your high idle feature.
Old Oct 10, 2004 | 11:33 AM
majora's Avatar
Well, I have an 04.5 and the cruise control high idle works fine. Was installed with TSB 18-004-04. Then it has to be turned on by the dealer using the DRBIII. Then I had the TSB 18-037-04 done and the high idle did not work. Has to go back in and turn it on again.
Old Oct 10, 2004 | 11:37 AM
moterhead's Avatar
Well the narrative in the TSB is wrong then. My mistake in believing what DC wrote.
Old Oct 10, 2004 | 12:32 PM
majora's Avatar
I think that there are a number of break points in the 04.5 engine run. My engine was built 01-11-04 and I know of changes that were later than that. It may be a check and see if it is for what you have. My dealer used the DRBIII scan tool to read the computer and determine what can be done. He read the computer then got online with the scan tool to find out what TSB's that I could use. He then downloaded the flash and installed it in the truck. Other than that, I have no idea what can and cannot be used. All I know is that I have a 04.5 and the high idle works great. Note that the computer was read with the DRBIII and not the ODBII.
Old Oct 10, 2004 | 02:40 PM
J BODY's Avatar
For awile the enable feature wouldn't work on the 04.5's, but all that has been corrected. You only need the DRB for the enable on the 04.5 on up. I have probably done close to a hundred of them now and will do more now that the snowbirds are starting to show up.
Old Oct 10, 2004 | 05:27 PM
BPD239's Avatar
motorhead, you could be right about it just needing to be enabled, but when I got the invoice back from the dealer it definately stated that they performed TSB 18-004-04 at the my request.
kicker210
Dec 2, 2009 08:23 AM
skahla
Nov 20, 2009 08:13 AM
jmccart
Jun 12, 2007 02:12 PM
LanceK
30
Nov 11, 2006 09:28 AM
rjm022
Oct 28, 2005 12:22 AM
