High Idle Enable...How does it work?
Old Nov 1, 2006 | 04:09 PM
LanceK's Avatar
Got it done at Dealer but don't know how it works or specifically when and how long to use it.
TIA
Old Nov 1, 2006 | 04:12 PM
rustyshakelford's Avatar
turn the cruise on. press set. that should take it up to about 1k. then use accel and decel to adjust. i use it for extended periods of idle time, or if your having to winch
brett
Old Nov 1, 2006 | 04:13 PM
LanceK's Avatar
Ok I assume having the truck in Neutral is what triggers it to do the high idle instead of cruise control.
You don't need set parking brake or anything else?
Old Nov 1, 2006 | 04:54 PM
mine does it in park. im not sure about the parking brake as mine is always set. im fixing to run to the store in a bit and ill check it out unless someone esle chimes in first
brett
Old Nov 1, 2006 | 04:59 PM
Smokeman's Avatar
LanceK is yours a manual trans or auto?
Old Nov 1, 2006 | 05:03 PM
LanceK's Avatar
Mine's an Auto.
Old Nov 1, 2006 | 09:00 PM
3rdGen's Avatar
Mine works exactly like Brett said. My park brake is set and tranny in park.
Old Nov 1, 2006 | 09:03 PM
3rdGen's Avatar
Lance did you call 911? Cuz you got us hehe.
Old Nov 1, 2006 | 09:04 PM
haha thats funny.
this is definately a pro-union thread it seems
brett
Old Nov 6, 2006 | 07:27 PM
LanceK's Avatar
Ok I tried the method(s) above and nothing.
1. Start truck
2. Turn on Cruise
3. Press set
Tried with both parking brake on and off.
Am I doing something wrong or did the dealer never enable it?
Old Nov 6, 2006 | 07:34 PM
Gary C's Avatar
Smile
brett
What do you consider extended?
What RPM do you have it adjusted toooo when doing so?
thanks
gary
Old Nov 6, 2006 | 07:36 PM
Tom282's Avatar
1. Start truck
2. Turn on Cruise
3. Press set
I found that on my truck, I don't need the emergency brake. I start the truck, turn the cruise control on, and then press and hold the set button for about 2-3 seconds and it comes right on. If your truck is an '06, it should have come from the factory with it turned on. Try holding that set button for a few seconds. I was pressing it and letting it go too quick at first. Let us know how you make out.
Old Nov 6, 2006 | 08:14 PM
Hairtrigger's Avatar
I have an '05.
Do dealers charge for TSB's?
Old Nov 6, 2006 | 08:33 PM
this did not come standard on our trucks. i had to have mine enabled at the dealer. as for the tsb, im not sure there is one. its just something that they enable with the star scan tool. takes literally about 45 seconds once they hook it up. and you can use it in neutral w/ the park brake set
if i go to the bank, ill kick the idle up to about 1k. i never know if im gonna be 5 mins or 30 depending on how slow some people move. besides i like hearing it run
brett
Old Nov 7, 2006 | 02:55 AM
Jreif80's Avatar
mine actually does it on it's own with my 6 speed in nuetral and my park brake set when it's cold
