How to change from Dino oil to pure Synthtic....
I have been told to blend the synthetic with the dino oil for a few oil changes increasing the synthetic, then go all synthetic. What do ya say. Should a person just do a one time change from Dino oil to Synthetic or blend the two oils for a few changes?
IMO I was thinking just do a one time change over, but i could be wrong.
One time change is all you need. In fact, I have never heard of mixing dino and synthetic together during the same oil change.
I'd just switch it over and be done with it. There are blends out there, most all the additives put into dyno oils are synthetic. But to go through the blending process yourself?? NAW, thats NUTS, just change it out.
CD
CD
Just switch it out. Your going by old school rules back when regular oils didn't have additives. Back then the engines would get gummed up (sludge) because the conventional oils didn't have or had very little additives. Todays conventional oils are so close to synthetic oils that they can be called synthetic and some companies do list them as synthetic.
Synthetic vs. Conventional Oil = Night vs. Day
A synthetic oil's molecules are much more consistent in size and shape, they are better able to withstand extreme engine temperatures. By contrast, the unstable molecules in conventional oil can easily vaporize or oxidize in extreme heat. Mobil 1 synthetic is said to be capable of protecting engines "at well over 400 degrees F"; in the real world, most racers have no problem running synthetics up to 290 degrees F under prolonged use, but they get really jumpy when a conventional exceeds 270 degrees F.
An 0W-30 synthetic oil is capable of pumping easily at -62 degrees F and flowing at even lower temperatures. Conventional oils are essentially frozen solid at that temperature, so there's simply no conventional equivalent to this new grade. There are 5W-30 conventional and synthetic oils, but even here, the synthetic has a real-world advantage: Mobil 1's 5W-30 will pump at -58-degrees F, compared to about -35-degrees F for a conventional oil.
cminzey
Aug 4, 2013 03:27 PM
Franklin
May 20, 2008 02:02 PM
ctd4stan
May 14, 2008 12:39 PM
RHC
35
Oct 22, 2007 05:46 PM
