Change Oil from Synthetic back to Dino
I have heard that once you start using 100% syn oil that you can not go back to regular oil. I've read some (not all) the threads re: using syn. At my infant stage, I'm not getting into the discussion of which is better - syn vs. dino
If I use 100% syn at the next oil change, then later decide to go back to regular dino, are there any issues with that? Has anyone done that?
thanks.
thanks.
No issues at all whatsoever. Syn oil will loosen up sludge in the engine so if you switched BACK to Synthetic I might run a shorter interval the first time before changing it. I have gone back and forth with no problems and great UOA's.
Very Good Advice about doing a short OCI after using regular and going back to group 4 or 5 synthetic oil.
Oilburner04
13
Nov 13, 2008 06:03 PM
RHC
35
Oct 22, 2007 05:46 PM
jlipskoc
Mar 7, 2006 06:53 PM
wild4stangs
Jan 25, 2006 08:49 AM
