High Idle on 05 2500 auto?
Old Feb 2, 2006 | 11:03 AM
magman's Avatar
Can you get the high idle enabled on a 05 2500 auto?
Old Feb 2, 2006 | 12:48 PM
reidry's Avatar
Yes,
Just had my dealer do this on my '05 Auto 2WD. Call ahead, make an appointment and be sure that the service desk talks with the diesel tech. The local diesel tech was not familiar with the procedure until after I called. I do live in Central Florida so it was no suprise that he was not familiar. By the time I arrived he was up to speed and had it done in minutes. While I was there (less than 1 hour total) they also put the new design door seals on my truck.
Ryan
Old Feb 3, 2006 | 05:45 PM
redspider's Avatar
new design door seals?? i knew the 06's had improved new design door seals, is there a tsb or a recall for this? or did you pay for the new seals. dodge was claiming that 60% less noise on the new 06 rams because of these seals.
Old Feb 3, 2006 | 08:13 PM
HorseHauler's Avatar
Just take it in and the dealer will replace it under warranty if they are ripping. What year truck do you have? Fill in your sig so we can help out better
Old Feb 3, 2006 | 08:45 PM
BigGunZ's Avatar
Get a Bully Dog downloader. You can enable high idle. Disable the horn chirp when you lock your doors. Change the way your doors auto-lock. Change the timer setings for the headlights, and several other features.
Oh yea....almost forgot.......you can do crazy burnouts in a 7300 lb dually
Old Feb 4, 2006 | 01:07 PM
redspider's Avatar
oh the ripping issue. I havn't had any problems yet, im only @ 18500 km though.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
