High EGTs what to do ?
Old Oct 3, 2010 | 06:37 PM
blue punisher's Avatar
need some info on this it runs 1300 empty and goes up to over 1500 when hauling 7 ton or so what should i do to get them down
Old Oct 4, 2010 | 01:00 AM
05dodgebrad's Avatar
wastegate valve sticking open sometimes? turbo rpms too slow or too small of a turbo?
Old Oct 4, 2010 | 02:19 AM
rich's Avatar
wheres the probe located pre turbo or after
Old Oct 4, 2010 | 07:52 AM
cincydiesel's Avatar
Are you running with both BD and Dr. P stacked? If so, theres your problem
Old Oct 4, 2010 | 05:10 PM
the proromiter is pre turbo
Old Oct 4, 2010 | 05:18 PM
__________________
Ive run both ways it dont seem to matter
Old Oct 4, 2010 | 06:16 PM
Nitrouskix's Avatar
you need higher rpms while towing like 2200-2500 rpm. The 74 turbine is slow to spool at lower rpms like below 2000. You may find it better to tow with O/D off going about 60 mph. That's what I do with 33s and 3.73 gears. Although mine is 66/74
Old Oct 4, 2010 | 06:59 PM
ill try that
Old Oct 6, 2010 | 03:38 PM
no_6_oh_no's Avatar
Sounds pretty normal just stock. If you have the boxes turned on and thats all your seeing I'd say its pretty good.
lgp9999
Sep 8, 2007 11:19 PM
Bradleysram
32
Nov 25, 2004 09:25 AM
BCarmicle
Sep 22, 2004 12:10 PM
Towrig
18
Jul 16, 2004 02:34 PM
NOTSTK
Aug 9, 2003 09:10 AM
