high egts, Loss of Power
Old Nov 28, 2010 | 05:55 PM
yoda76's Avatar
ok here is the story. I have had my camper 5 years pulling with this truck. I've never had a problem pulling my camper until this year. I though it could have been fuel related (old fuel) but every time I pulled this year seems to have higher egts that years past & not the power I had before. Earlier this year I change the exhaust system to a 5" cat back. I thought that this would drop egts not raise them. I think that this problem may have been before I changed the exhaust. I only notice a big problem when I'm towing. the other wierd thing I noticed is when I used to sit stop at a light my egts used to sit at 400 deg. now it will starts there and raise to 500 while i'm sitting at a light. I'm looking for some insite on this problem so I know where to start. the truck only has about 49000 miles on it. Also another side note when i'm towing and pushing the truck I would used to get some good black smoke. I'm getting none. Is this injectors, catalytic converter, torque converter?? Is this something someone can find hooking it up to a diagnostics computer?
Thanks for any input.
Old Nov 28, 2010 | 07:54 PM
2007 5.9's Avatar
Boost normal??
Checked boost hoses and clamps??
Old Nov 29, 2010 | 07:22 AM
yoda76's Avatar
actually yes I was pushing 20-25 lbs of boost while at beween 1100 to 1200 on the egts
Old Nov 30, 2010 | 03:51 AM
MDCS's Avatar
Air filter?
Old Nov 30, 2010 | 09:24 PM
no_6_oh_no's Avatar
Check your LP pressure at the CP-3. Symptoms could indicate a loss rail pressure. If you haven't updated the LP might be time.
Old Dec 1, 2010 | 12:22 PM
yoda76's Avatar
I have an appointment at the dealership tomarrow hopefully they can find whats wrong with it. Also hopefully its covered under the 7 year 70000 warranty.
Old Dec 9, 2010 | 06:21 PM
yoda76's Avatar
got truck back today. They replaced the lift pump & the cp3. They covered the cp3 & I had to pay for the lift pump.
Old Dec 9, 2010 | 09:19 PM
JP-4.5's Avatar
How many miles on old CP3? Did this service cure your troubles?
Old Dec 10, 2010 | 08:07 AM
yoda76's Avatar
only 49000 miles on my truck. The biggest problem is that I woun't really know until about April- May of next to see if this is fixed because I put my camper in storage for the winter. My big question is why did both of these pumps have to be replaced? Did my MP-8 controller have something to do with it? The truck seems alittle more responsive not huge or anything.
Old Dec 10, 2010 | 08:53 AM
no_6_oh_no's Avatar
LP goes bad and it starves the IP a little at a time. Low fuel pressure at the CP-3 translates to robbing cooling\lube fuel to maintain rail pressure, cavitation in the CP-3 gear rotor pump from low suppply pressure hammers the drive shaft and spits metal fragments into the pump and eventually the injectors.
Yours is a perfect case that CP-3's are NOT made to draw their own fuel thru the lines on a Dodge or damage and failure will ensue.
Old Dec 10, 2010 | 05:42 PM
yoda76's Avatar
did my TS mp-8 have a demise of my pumps?
Old Dec 10, 2010 | 06:41 PM
no_6_oh_no's Avatar
Directly no, indirectly maybe. The MP-8 raises rail pressure to the injectors. Theoretically it COULD contribute but over working the CP-3 IF it was starved for fuel. That would be the indirect contribution and is pretty tought to prove or even document.
More than likely, time and a weak LP is what did the pump in. The MP-8 is a good compromise as long as you don't go over about 20% for long periods of time. The boost fooling and extra pressure help with efficiency but too much pressure will kill the injectors.
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
lgp9999
Sep 8, 2007 11:19 PM
BCarmicle
Sep 22, 2004 12:10 PM
