hex key size for '05 G56 Tranny drain & filler plug
Old Dec 10, 2005 | 11:17 PM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
OK folks, so what size hex key (allen wrench) do I need to use on the drain and filer plug for the G56 tranny?
By the way, I was surprised that the G56 uses the ATF+4 same as the transfer case, but that's what the dealer said and confirmed with my owner manual.
Old Dec 11, 2005 | 11:41 AM
GndHog's Avatar
As I guess that you have already discovered, neither the users manual nor the '05 service manual specifies the size of the wrench. I don't know either, but the service manual did list the torque specs. Both drain and fill plugs are the same: 57N-m 42 ft. lbs. Hope this helps!
Old Dec 11, 2005 | 07:02 PM
mschwe's Avatar
I bought a three pack at Auto Zone for about ten $$ that had the 14mm allen, that fits on a 3/8 socket. A 9/16 SAE socket will also work.
Old Dec 11, 2005 | 07:05 PM
mschwe's Avatar
Smile
Just a correction on my ealier reply. A 9/16 allen will work NOT a socket. A 1/2 inch allen will work but it will be loose.
Old Dec 11, 2005 | 07:09 PM
jr22's Avatar
if i remember right its a 14mm hex
Old Dec 11, 2005 | 08:55 PM
snakefarmer's Avatar
It's a 17mm hex key, just changed my fluid recently.
Old Dec 11, 2005 | 09:41 PM
bulabula's Avatar
It is a 17mm hex on the NV5600's; dunno about the new G56.
Old Dec 12, 2005 | 08:21 AM
Steve034x4's Avatar
Thanks, folks.
I'll go visit Sears for a 14mm hex key. Late last night I took some measurements and figured it would either be a "large 13mm" or a 14mm.
Figured it had to be metric.
ps. I have a slightly used 17mm from my old NV5600 - won't fit the G56 (it's the first thing I tried).
93oilburner
Nov 1, 2011 01:10 PM
RobG
Sep 10, 2007 10:33 PM
WideOpenThrottl
Jun 17, 2006 06:30 PM
RAM2940
Jul 30, 2005 11:50 AM
03CTDCO
Jun 15, 2005 11:11 AM
