Help 2006 using oil
Old Sep 4, 2017 | 09:40 AM
Rusty Euler's Avatar
Help 2006 using oil
I have a 2006 Dodge dually with 6.7 cummings turbo. The other day leaving work got on road it started blowing white smoke out the exhaust pipe it got so bad i couldn't see behind me than the oil pressure went to 0 and died. Thought i had blown the motor. But it started again but the motor compartment was full of oil. Pulled back to where i work pulled out the breather filter in valve cover pulled dipstick and oil fill cap than started truck and after a couple of minutes the oil started coming out filler tube and dipstick and white smoke started blowing out again. What does anybody think it is ?
Old Sep 5, 2017 | 10:27 AM
FMB's Avatar
FMB
Welcome to DTR. If you do a search for similar issues you will find posts with similar issue. Try this post. Doesn't sound good though, maybe rings, maybe more depending on how long the engine ran with 0 psi on the oil pressure gauge. Good luck to you.
Back to morning brew . . .
Flo
15
Dec 5, 2007 07:27 PM
jmccart
14
Sep 17, 2007 08:23 PM
jrussell
17
Sep 17, 2007 06:38 PM
Common
Nov 18, 2006 10:31 PM
DanTana
Mar 6, 2006 05:56 AM
