hard to start
hard to start
got an 03 dodge.this prob started all of a sudden. The truck turns over till the batteries are almost dead begfore it cranks. When it cranks it runs fine. but when i shut it off wate a min it turns over longer than it should to crank. This is after driving the truck all day or 5 min. Iv got supply press to the pump took chip and programer off still makes no diff.
all 6 inj at once? Im a john deere master tec ver familur with high pressure com rail. Cummins is set up a little diff. with a few less check valves but cant see any problem with them. Today my dad used my truck i was lisening to him try to crank turning over and over well he grabs a can of eather and it fired right up what the ..... Its drivin me nuts
def. an injector or two. mine did and is currently doing the same thing. Is your truck making oil?? I have 5 friends that have had same issue, all with programers, very common prob. One of them has recieved 2 bad replacement injectors right out of the box so be careful. The tool that you use to isolate a single injector is simply a fuel line nut that is capped off, if you have old fule lines you can make one yourself. The truck wont start (most likley) because fuel is bleeding off during cranking and not building enought pressure for the rail pressure sensor to let the engine fire. Just remove one injector line at a time and cap of the rail where the line was and crank if truck starts you found the culprit.
jacob_armour
Feb 18, 2009 01:44 PM
jckdann7
Aug 31, 2008 12:13 PM
