Guidence for flooded truck-rear end and everything in between
Harvey flooded 05 2500 5.9 4x4 - what to drain/change
Hey guys, Its been awhile since I've needed your expertise on my 05 dodge 2500 4x4 5.9... So, I was flooded in Harvey and unfortunately my truck had sat in high water. Probably 1 to 2' in the cab. I've already done quite a bit, but I don't know much about the axles, rear end etc. Can one of you help me out with what I should do?
edited to add, i already cleaned transmission pan, filter and gasket and replaced transmission fluid, and oil. Basically the basics thst I know how to do.
I did already post this, but I think in the wrong category.
Open Your wallet, credit card's savings accounts, to the PARTS Vendor companies, first off start with all computer testing, next tranny overhaul, all wheel bearings, differential overhaul including bearings, fuel system, then interior, last for me is a complete wiring harness, as salt water will eventually destroy it all, short Idea get rid of truck;;;;
Sarajaye
04-12-2018 05:06 PM
SuperDave4x4
07-03-2004 03:48 PM
