grinding and vibration on 06 2500
Old Oct 12, 2008 | 09:37 AM
Pa outlaw's Avatar
Ive got a strange one here , my 06 2500 short bed has 4 1/2 " pro fab lift 34" toyo tires on it,when im at like 50-60 i hear it worse and it gets a lil worse the faster i go, when i go over a hump in the road where it unloads the springs it really gets bad, also does it when turning right some times but never did it going left, ive had it at the dealer 2 times now, they changed the converter which i told them it wasnt that because it doesnt change with rpm, it sounds like it has a built in peanute cherner under the truck, sounds like a grind and i can feel it in the truck, not always there but always there over 50mph im lost didnt know if anyone else had the issue or if its from the lift, its getting worse checked the hubs and u joints all seem to be good,changed tires same thing not that changing them would do anything for the grinding noince i feel thru the floor pan, almost feels like its up front, any help would be appreciated
Old Oct 12, 2008 | 02:17 PM
Ram Daddy's Avatar
Talking
More than likely you need the dropdown bracket for the transfercase....mine did the same thing when I added a 2in spacer on top of my 4in. lift , and it drove me CRAZY trying to figure out what it was. The dealer didn`t have a clue , and the guy I got the lift from didn`t know either , as he had the lift on his truck with NO noises....
I got mine from Superlift (as well as the correct 6in. springs...no more spacers), and it totally cured my noise/grining problems.
Old Oct 12, 2008 | 05:32 PM
Pa outlaw's Avatar
i will look into that bracket,boss has a 4 inch on his but doesnt do what mine does but at this point i need to find something, nice, my wife has a 05 r/t magnum too!
Old Oct 12, 2008 | 05:36 PM
megacabdad's Avatar
How long have you had that lift on?
Almost sounds like a wheel bearing to me...
Old Oct 12, 2008 | 05:41 PM
Pa outlaw's Avatar
i bought it with it on, only had 7000 miles on it when i bought it, but from the day i picked it up it was there, i jacked the thing up numerous times and checked the wheel bearings and the are good, im going to try the tranferr case bracket once i figure out the part number to get it,thanks,mike
Old Oct 12, 2008 | 05:44 PM
megacabdad's Avatar
OK...
If it's been doing it that long...
Can't believe whoever installed the lift didn't put the drop bracket on.
Old Oct 12, 2008 | 07:55 PM
Pa outlaw's Avatar
it has been getting worse since i bought it, it was there here and there now it more than there, really notice it the most towing when it takes the weight off the front end and going over a hump in the road thats why i believe it may be the tranferr case bracket too,ill get that and try it first, i get rid of the **** noise ill be happy thanks for everyones input so far, dont know unless you ask
Old Oct 13, 2008 | 03:48 PM
Ram Daddy's Avatar
Talking
I would be VERY suprised if the drop bracket doesn`t cure it...
BTW...truck looks good , but you need to add some pics to your gallery , so we can see a bigger picture of it
Rednecktastic
17
Jul 10, 2009 07:46 AM
xzaq103
Jan 19, 2008 08:53 AM
MARKY MARK
Feb 1, 2007 10:46 AM
cLAYH
Feb 6, 2004 10:59 AM
