G56 Manual Transmission Refill
Old Sep 2, 2012 | 02:08 PM
6spd05Dually's Avatar
This is concerning the refill of fluid on my G56 manual trans. Instead of refilling the fluid on right side of trans., can the fluid be refilled through gear shifter cover inside truck?
Yesterday, I went to change the fluid and forgot to put the washer on the drain plug. I didn't have a stubby hex bit so had to drop the exhaust to get my hex bit in refill plug. A real PITA!!!! I want to get that washer back on the drain plug asap. Please reply if you know for sure this can be refilled through gear shifter to avoid the side refill plug. Thanks
Old Sep 2, 2012 | 08:22 PM
marathon's Avatar
I've added a qt through there at every change, so it can be done. How long will it take to go down through the entire system? Will it back up and overflow if it takes a while? Don't know.
I would guess that if you watched the process carefully, not overfilling it and, after all the required fluid is in, wait a while so the liquid can settle down before driving, it should work.
Old Sep 3, 2012 | 03:06 PM
You would think the fluid would go down to the bottom of the trans just like oil does in an engine pretty quick. As I stated before, I just want to put that gasket back on the drain plug. I have been watching for leakage, but none so far. Thanks for your reply.
Valv
May 23, 2009 07:36 PM
EClancy
Nov 15, 2005 03:48 PM
hotdram
Feb 8, 2005 08:54 PM
GaCamper
Feb 4, 2003 12:30 AM
oldroy
Oct 18, 2002 07:06 AM
