flush and refill power steering system?
Old Nov 15, 2005 | 12:10 PM
EClancy's Avatar
Anyone know a good way to flush as much bad power steering fluid out of the system as possible. Mine kind of looks like watery oatmeal. Kind of scary. My factory service manual does not talk about draining and refilling.
Old Nov 15, 2005 | 12:22 PM
Underpsi's Avatar
You could take bolt lines off then take the bolts off for the reservoir and take the reservoir right off but im not sure how to get it out of the power steering box. Maybe while the lines or off turn the steering wheel to one side and then the other??
Old Nov 15, 2005 | 03:04 PM
Rattlerattle's Avatar
I use a suction gun to get what I can out of the reservoir. Add new fluid go for a drive and use the suction gun again. Normally two or three times seem to work well for me.
Old Nov 15, 2005 | 03:10 PM
andyr354's Avatar
you can flush it with a buddys help. Take the return off the pump and put it in a bucket. Plug the return on the res so it will hold fluid again.
Get ready with a funnel and start her up, when the wheel is turned it will dump fluid out of the return into the bucket and you will need to keep adding fresh to the res.
It is more of a PITA process but if you are particular about it it is possible to do.
Old Nov 15, 2005 | 03:48 PM
EClancy's Avatar
yeah, i was thinking the suction gun too. Thats how we do the Macks at work, but they hold like 2 gallons of 15-40 as power steering fluid, so i would imagine this can't be as bad.
also, good idea on taking the return line off
Thanks for the ideas
CACalomino
16
Mar 22, 2010 06:35 PM
Valv
May 23, 2009 07:36 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
LFD2037
Nov 8, 2006 09:12 PM
