47re transmission trouble
Old Sep 3, 2012 | 12:30 AM
ehohn's Avatar
10 Year Member
2003 quad cab bought it 2006 w/83k and have 215k now. lots of things have gone wrong, lift pump went out replaced with fass95 $495, then it would not start. I replaced six injectors with 50 hp nozzles $2200, Then axcelleration became erratic, I replaced throttle position pot $545. Two water pumps . Now the transmission is slipping. about a mile from the house trans would not shift in to second gear then lost all forward drive. if i shut it off and restart it will move in any gear selection to 20 mph then slip until i shut down and restart. changed fluid (5.5 quarts & filter at about 200K, looks and smells a little burnt now. What do you think is the problem.
Old Sep 3, 2012 | 01:49 PM
ehohn's Avatar
10 Year Member
i am new at posting here but all the repairs on my truck have been made possible from reading this forum, there are alot of very experienced owners her that might have had the same transmission trouble. i have ordered a rebuilt valve body with the governer solinoid and sensor anybody please repiy
Old Sep 3, 2012 | 02:12 PM
Lost Lake's Avatar
It isn't the VB. Your front band may be shot not allowing the shift to happen.
Old Sep 3, 2012 | 02:58 PM
1-2-3's Avatar
Just a plain ole guy
yep. my 99 did the same thing and it was a band issue. Might as well rebuild it all if your gong that far.
Old Sep 3, 2012 | 05:46 PM
ehohn's Avatar
10 Year Member
i have not the band adjustment, and it has been slow to shift from first to second many times in recent months, has anyone rebuilt one of these 47re, the only code is p0700
Old Sep 3, 2012 | 07:30 PM
1-2-3's Avatar
Probably a code set due to the trans not shifting right. Remember, that codes in alot of cases tell you the symptoms, not the actual problem
thehemikid
Feb 25, 2021 12:45 PM
mkrenn
13
Sep 24, 2010 04:30 PM
Munchies
Oct 19, 2006 06:09 AM
Mechanos
Oct 18, 2005 05:55 PM
BIGBADBOB
Mar 27, 2004 08:09 PM
