Fuel Rail Leak
Old May 2, 2005 | 10:34 AM
MonroeDiesel's Avatar
Fuel Rail Leak
There was some residual fuel on the rail, not wet , but you could tell some fuel had seeped out. Also around the injector bolts. I don't want to exagerate, it wasn't alot but it just worried me. Is this normal somewhat? Could some tightening down help this?
Old May 2, 2005 | 06:17 PM
Dodgezilla's Avatar
There is a gasket at the pressure relief valve that tends to leak if you run a pressure box. It only costs like $2.00 from Dodge. I had one go bad and the wind from the fan blew it all over so it looked like several leaks. It's very simple to change. I'd suggest cleaning it all off pretty good and then fire it up to see where the actual leak is.....
Old May 2, 2005 | 07:22 PM
Thanks for the reply, I sprayed the area with brake cleaner and hot water. Ill see how it turns out
Old May 3, 2005 | 12:12 AM
gatf4's Avatar
My fuel pressure sensor went bad and was leaking. It took a while to pinpoint because of all the fuel fittings in that area, let us know.
M1AM14SPUR
Dec 1, 2010 03:38 PM
sallyman1
Feb 14, 2009 12:30 AM
jsafe
May 2, 2008 09:45 AM
5.9Excursion
Mar 13, 2008 10:56 AM
610dodge
Dec 9, 2006 02:26 PM
