Fuel Rail Leak
Old Nov 27, 2010 | 09:30 AM
M1AM14SPUR's Avatar
Fuel Rail Leak
On my fuel rail, there is a line leaking at the fitting that goes to the fuel stick. It isn't just loose, it is leaking at the fitting on the actual that is on the tubing. Has anyone else expierenced this? Where would I get a replacement? I am checking at some hydraulic shops on Mon to see if they can fab one. It seems like every time I turn around something is going haywire on her lately!
Old Nov 27, 2010 | 10:53 AM
J BODY's Avatar
should have tightened those line isolators..... Bet you cracked a line.
Old Nov 28, 2010 | 10:25 AM
DieselLady's Avatar
Not sure what the fuel STICK is, but I know that the dealer keeps the #4 injector line in stock because it fails so often. And that would be right where the end is connected to the line.
Old Nov 28, 2010 | 05:13 PM
M1AM14SPUR's Avatar
Thanks guys, do you have an idea what the dealer would charge for the part?
Old Nov 28, 2010 | 05:21 PM
DieselLady's Avatar
I think it is only like $50 or so.
Old Nov 28, 2010 | 07:16 PM
Condor's Avatar
If it is an injector line, and you have a local cummins dealer get your line there, it will be alot cheaper.
Old Dec 1, 2010 | 03:38 PM
M1AM14SPUR's Avatar
Isn't there a place online where you could get salvage parts? I called Dodge and they want $50.00, and I need to go get the serial numbers off my engine tomorrow so the Cummins guys can get me a price.
sallyman1
Feb 14, 2009 12:30 AM
jsafe
May 2, 2008 09:45 AM
5.9Excursion
Mar 13, 2008 10:56 AM
610dodge
Dec 9, 2006 02:26 PM
MonroeDiesel
May 3, 2005 12:12 AM
