bad oil leak
Old Apr 25, 2005 | 11:00 PM
hovisimo's Avatar
bad oil leak
posted at DR but will post here too since you guys know your stuff too...
i check my oil every week... it hasn't yet been a week. found an 8" wide puddle of oil on my garage floor this morning, checked the oil and it was 3 quarts low. i can't pinpoint the leak, looks like its coming from between the torque convertor and engine, though. truck has 14,800 miles and a stock engine. i'm taking it in wed, anyone have this happen and if so what was it?
Old Apr 26, 2005 | 12:01 AM
BlueDually's Avatar
my guess is rear crank seal
probably have to pull motor
Old Apr 26, 2005 | 12:24 AM
hoser's Avatar
no , you pull transmission.
Old Apr 26, 2005 | 08:09 AM
trik396's Avatar
Looks nasty. How often does that happen?
Let us know the results.
T.
Old Apr 26, 2005 | 05:00 PM
bigblock2stroke's Avatar
Could also be cam seal.
Doesn't happen too often, but I have seen it a few times. High crankcase pressure can affect the seal. So can a damaged crank vib damper.
Old Apr 26, 2005 | 06:51 PM
Hounddog's Avatar
Have you looked higher up?
Old Apr 26, 2005 | 06:57 PM
wexman's Avatar
That brings back memories of my Powerstroke - HPOP O rings went, and it looked like the Exxon Valdez. Needed a 30 mile tow to the dealer. Then, 5 weeks later, did it again. That was the final straw for me getting rid of that truck.
Please keeps us posted on what this is.
Old Apr 26, 2005 | 07:08 PM
Fronty Owner's Avatar
rear main seal would be my guess.
Isn't the cam on the cummins front loaded like all other engines?
Old May 1, 2005 | 10:37 PM
bauer500's Avatar
Its your valve cover gasket, mine did the same thing and dodge replaced that and the rocker cover gasket and it is good as new.
Old May 3, 2005 | 05:58 AM
Hounddog's Avatar
Well its been a couple of days.What was the leak?
Old May 3, 2005 | 10:20 AM
The cam is front loaded, but there is still an o-ring that seals the rear face of the block to the rear cam journal.
hardheaded
Apr 3, 2008 09:43 PM
65fury
25
Apr 6, 2007 08:16 AM
6speedcowboy
Jan 14, 2007 01:41 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
