Boost Gauge Install Question....
Old May 2, 2005 | 10:23 AM
zog's Avatar
zog
Ok, so I am all set to install my boost gauge...I open the package and I see there is a plastic "TEE" and some connections that come with the gauge...
I am thinking this is good, and I don't have to drill and tap the intake, but there are no instructions with the thing!!!
Anyone know how to hook this guy up???? Thanks
Old May 2, 2005 | 11:28 AM
MikeyB's Avatar
I believe the only way to hookup a boost line on a Cummins is to either drill and tap the intake manifold or get a boost bolt from either Geno's Garage or Piers Diesel Research. The boost bolt replaces one of the intake manifold bolts and has a barbed fitting to plug the line into.
MikeyB
Old May 2, 2005 | 11:29 AM
MedicShawn's Avatar
I have a picture of my boost bolt into the intake in my gallery.
Old May 2, 2005 | 03:56 PM
pcburnout's Avatar
My kit came with a type fitting where you remove intake blot and screw one provided in no tapping. or I believe Tee is placed on waste gate line for boost.
Old May 2, 2005 | 04:01 PM
ozman3918's Avatar
I got a banjo bolt on mine.dieselmanor.com sells them also.Replaces bolt on intake, painless installation.
Old May 3, 2005 | 11:10 AM
Maccandy's Avatar
zog
Make sure you clamp both ends of the rubber tube! It will blow off if you don't.
Tank_66
Feb 28, 2008 08:34 PM
cuccamonga
Dec 28, 2007 01:41 AM
NeedMoPower
Mar 12, 2005 04:38 PM
jbs007
Jul 24, 2003 12:58 AM
soundfetish
Feb 26, 2003 02:37 PM
