Fuel leak...
Old Apr 9, 2003 | 09:18 PM
MikeyB's Avatar
Fuel leak...
I noticed this evening some drips under my new baby. Checked and it's diesel fuel. After searching for a few minutes it appears to be coming from this black canister mounted on the fuel filter housing since it's soaked with diesel. Looks like some type of electric pump.<br> Anyone else seen this problem?<br><br>Thanks<br><br>MikeyB
Old Apr 9, 2003 | 09:49 PM
Sittenbull2's Avatar
Re:Fuel leak...
Mikeyb <br><br>Sorry About what you found with Diesel leaking I have not had no problems yet with fuel leaking where you described. Take it back to dealer let them fix it 5yr 100,000 mile warranty or the 3 yr 36,000 mile warranty want cost you nothing.
Old Apr 10, 2003 | 07:23 AM
MikeyB's Avatar
Re:Fuel leak...
Luckly it's not leaking bad (yet), just a few drops on the ground. I did notice the mounting bolts wasn't very tight, so I retorqued them. I'll keep an eye on it for few days and see what happens.<br> While I was under the truck I noticed the beautiful patina rust red on the tranny case and driveshaft. I guess Dodge is trying to save a few cents....... :<br><br>MikeyB
Old Apr 10, 2003 | 05:29 PM
mymaur's Avatar
Re:Fuel leak...
I'm with you on the rust red tranny and drive shaft. They also skimmped on the steering mechanisim. Go figure. Soon as our rain lets up and it's warm again in sunny south carolina. I'll get under there and solve that with a nice can of silver rustoleum.<br><br>I also have no leaks.
Old Apr 10, 2003 | 09:49 PM
Nevada's Avatar
Re:Fuel leak...
[quote author=MikeyB link=board=20;threadid=13419;start=0#126258 date=1049941137]it appears to be coming from this black canister mounted on the fuel filter housing[/quote]<br><br>That would be your lift pump.
Old Apr 11, 2003 | 07:22 AM
MikeyB's Avatar
Re:Fuel leak...
Thanks for the info Nevada. I hope the '03 won't have the dreaded lift pump issues as the earlier model. And from the design it will appear to be a dealer only item.<br> Knock on wood, hasn't leaked since retorquing the mounting bolts.<br><br>MikeyB
Old Apr 11, 2003 | 08:14 AM
bulabula's Avatar
Re:Fuel leak...
Are you implying DC uses cheep rust?
Jaybug
Dec 24, 2013 11:23 PM
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
