Fuel Filters replacement?
Old Feb 17, 2010 | 09:31 PM
nwbowhunter's Avatar
Dodge 5.9 diesel Cummins motor.
Per Dodge recommendation fuel filters are supposed to be replaced every 10,000 miles driven. How critical is this? Thoughts?
Also, does any know if there is more than 1 fuel filter for the 2005 Dodge 5.9 diesel Cummins motor? To my knowledge there is only one on the truck.
Old Feb 17, 2010 | 09:38 PM
bansh-eman's Avatar
Just the one that is in the canister on the fire wall. I change mine every oil change (9k miles) I am starting to use the Baldwin PF7977 because it is a 5mic filter unke the stuff you get at the auto parts store.
Old Feb 17, 2010 | 09:48 PM
Okay cool. I notice that if I wait much more thank 10K my MPG gets bad quickly. I usually just buy one from the Dodge dealer.
Old Feb 17, 2010 | 09:51 PM
bansh-eman's Avatar
The Baldwin is better than the OE filter. Another option is the Fleetgaur filter. It is only 7 mic but it's also better than the OE which is 10 mic.
Old Feb 17, 2010 | 10:15 PM
What does the MIC mean? I assuming that the Baldwin PF7977 will fit my 2005 5.9 cummins motor?
Old Feb 17, 2010 | 10:18 PM
bansh-eman's Avatar
Micron... It is a unit of measurement of how small of a partical it will filter... The smaller the number the better filtration it has. But keep in mind you want the Absolute number. Some filters will say 7 mic but thats nominal, in actuality they are like 10mic absolute.
Yes the Baldwin is a direct swap for the stock filter canister that is bolted to the firewall.
Old Feb 17, 2010 | 10:20 PM
bansh-eman's Avatar
If you have a Grainger locally to you, they carry all the Baldwin filters...
Here are all the ones for your truck:
Lube BT7349
Air PA4162
Fuel PF7977
Transmission Filter 18055 (This is nothing more than an OE filter in a Baldwin box)
Old Feb 17, 2010 | 10:44 PM
Thanks for the information. Very helpful. After searching the part number the price for the filter seems way better than the price for an OEM filter.
Old Feb 17, 2010 | 10:51 PM
bansh-eman's Avatar
Yrp, most of them time the after market items that are better than stock OE are also better priced.
Old Feb 18, 2010 | 05:25 AM
AlCorr's Avatar
I pick mine up at the heavy duty truck parts store.
Baldwin
fuel - PF7977
oil - BT7349
Old Feb 19, 2010 | 02:00 PM
SuperGewl's Avatar
If yo don't put that many miles on your truck then you should at least change the filter 2 times a year. Before and after the winter months, if nothing else to help with the crappy fuel they swicht to for winter.
Old Feb 19, 2010 | 02:07 PM
cbrahs's Avatar
the new ones from dodge are 7 mic
Old Feb 19, 2010 | 02:31 PM
Ace's Avatar
Ace
OTR trucks and commercial equipment spec fuel filter changes based on either pressure or vacuum in the fuel supply, depending how it's designed.
Old Feb 19, 2010 | 05:53 PM
I think this is my main issue is I put limited miles on my truck. The price of the Baldwin are a lot better than the OEM price thats for sure.
DodgeCowboy
Jul 23, 2008 10:12 PM
bcfitzsimons
Jun 26, 2008 12:17 PM
staarma
28
May 1, 2008 11:10 AM
fitzydog
Oct 12, 2007 10:23 AM
kelley15
Aug 20, 2007 04:52 PM
