fuel filter replacement
Old Feb 23, 2008 | 05:35 PM
kram's Avatar
If possible can someone list the steps to replace my fuel filter on an 2005 Cummins. I am sure it is easy, but I have never done it before. I normally get the dealer to do it with an oil change, but it is due now and I have a few thousand kms before the oil change is due.
Thanks
Old Feb 23, 2008 | 05:49 PM
rjm022's Avatar
drain fuel filter bowl of fuel (yellow lever) unscrew cap- i believe it is a 1 1/8 socket. remove fuel filter and rubber o'ring on cap. replace rubber o'ring with new one and reinstall with new fuel filter. you may want to wipe your fingers down in the fuel bowl to see if you have any gunk in there, to be on the safe side.
Old Feb 23, 2008 | 05:58 PM
DiEseLjunKy's Avatar
Be sure to prime it before you start it up. It's easy. Takes about 10 minutes and you'll kick yourself for ever paying to get it done. Here's a writeup with pics: http://www.dodgeforum.com/m_485543/tm.htm
Old Feb 25, 2008 | 01:50 PM
DBLR's Avatar
Just make sure you use either the Baldwin PF 7977, Fleetguard Stratapore filter or the Mopar filter as they are 7 micron or smaller. BTW, many parts places are still selling the older 10 micron fuel filter. FYI, Cummins requested that all CR engines use a 7 micron or smaller fuel filter starting back in June of 2006.
Old Feb 25, 2008 | 01:56 PM
bansh-eman's Avatar
where are you guys getting the Baldwin PF 7977and Fleetguard Stratapore filters? I changed my filter out but all Napa had was thier version. and im sure its not smaller then 10 micron
Old Feb 25, 2008 | 02:03 PM
Truckman0097's Avatar
www.genosgarage.com
Old Feb 25, 2008 | 03:33 PM
DBLR's Avatar
You can get the 5 micron Baldwin here for $13.69 or less if you buy 3 or more: http://www.adiesel.com/store/PF7977.html
Old Feb 25, 2008 | 04:24 PM
mkivbren's Avatar
when you go to the new filter, it loses the "cap" thingy thats clipped into the lid. Be sure to pop that thing out as it is not used with the new style filter. I didn't know this and could not get the cap back on!
storx
17
Jun 29, 2006 01:33 PM
rjrkihap
Oct 4, 2005 05:09 PM
Alberta50
Dec 8, 2003 11:29 AM
The Old Man
Oct 27, 2003 06:03 PM
Duffy
Apr 21, 2003 03:05 PM
