front drive shaft spining in 2wd????????help please
Old Feb 17, 2008 | 09:25 AM
griffy's Avatar
the other day i noticed when i put my truck into 4wd then put it back into 2 it stayed in 4 for a bit longer than it should have also noticed my front shaft is spinning all the time even in 2wd could use some help please!!!
also got code p 0236 not likely to do with the 4wd problem but i woulndt mind knowing what it is.
Old Feb 17, 2008 | 09:49 AM
Stealth06Ram's Avatar
It always spins.
Stealth
Old Feb 17, 2008 | 09:54 AM
griffy's Avatar
ya i wasnt sure if it did or not must be something else wrong cuz something doesnt feel rite
Old Feb 17, 2008 | 10:14 AM
Howling's Avatar
You have to unlock your front hubs lol.
Old Feb 17, 2008 | 10:20 AM
griffy's Avatar
oh ya where is the button for the hub unlock i cant seem to find it j/k
Old Feb 17, 2008 | 10:51 AM
Jeff in TD's Avatar
He's messing with you.
The axles are bolted onto wheel hub on the 3rd gens. They don't unlock. When it's in 2wd, the front driveshaft is disconnected from power inside the transfer case, but the front axle and driveshaft always turn.
When you shift into 2wd from 4wd, it can take a bit for the shift to complete, as there may be quite a bit of torque between the two front axles.
Old Feb 17, 2008 | 11:41 AM
griffy's Avatar
yea i know he was messin around my last post was sarcastic kinda hard to get across with words thats why i said j/k
thanx for the help tho
Old Feb 17, 2008 | 01:25 PM
chamisi's Avatar
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality code
MikeyB
Feb 18, 2014 12:02 AM
cmann250
Nov 9, 2011 10:03 AM
Bad Ramer Jamer
Apr 17, 2008 04:22 PM
griffy
Feb 22, 2008 11:49 AM
