found leak spots??
Old Sep 13, 2004 | 08:58 PM
HorseHauler's Avatar
found leak spots??
i was just under my truck tonight looking for any leaking and i found two spots. a big one here on a bell type housing from the trannie i believe?? between the trannie fluid pan and the oil pan. and also a sticky type of substance coming from something above the driveshaft that has an orange tab with a pull loop thingy on it. does anyone know what im talking about? if so help. sorry for the lack of knowledge on these things, trying to learn... ill try to attach an image i just took, its not that great...
Old Sep 13, 2004 | 09:45 PM
03 ant a hemi's Avatar
hey mine is comming from the same place, I had the transmission input seal replaced. (red fluid leaking). I also still have an oil leak from the same area. check your oil filter and make sure it isnt leaking first, I suspect the rear mains on some of these trucks are leaking yet the dealers wont replace them unless it makes a real mess. keep us posted and I will also, my dealer put dye into the crank case to find out were the leak is comming from. good luck
Old Sep 13, 2004 | 09:50 PM
thanks ill keep posting, if anyone else finds out whats up with this let us know. also what is that plastic orange loop thing? anyone know?
Old Sep 14, 2004 | 07:29 AM
johnshole's Avatar
My truck was leaking from the lower vavle cover or rocker housing gasket and gathered oil there. It ran down the side of the trans/engine block and the back of the bellhousing.
Old Sep 14, 2004 | 04:32 PM
grandblanc's Avatar
I have a small oil leak coming from the driver side of the oil pan. Looks like it's dripping out of a black breather hose or something. Anyone else have this and is it normal?
Old Sep 14, 2004 | 06:26 PM
cquestad's Avatar
That is the blow-by/beather hose...it will spray some oil all over the side of the oil pan, bell housing, and even the front of the tranny pan. If you look real close, I bet that is the cause of the so called leak. I can wipe mine all clean towards the ned of an oil change interval and it will stay that way for weeks. I don't think it is from a leak so to speak.
Old Sep 14, 2004 | 08:24 PM
HdPower's Avatar
I agree with cquestad, mine has a light film of spray on the oil pan area as well and traced it back to the crankcase vent hose.
Old Sep 14, 2004 | 10:52 PM
you have a good point i noticed that breather hose with oil wet around it and my tranny pan is in fact oily also in the front of the pan. i bet thats where it is coming from. thanks everyone, made me feel a lil better
Old Sep 15, 2004 | 03:06 PM
grandblanc's Avatar
I only notice the small drops of oil on the floor after the truck sits for a day or two. Is this typical? I don't have any oil spray on the oil pan or the tranny pan.
Old Oct 12, 2004 | 09:05 PM
bauer500's Avatar
Mines been leaking there as well from the day I got it, I've had it at the dealer for this problem once before and they said it was just blow-by, but that wasn't it I brought it back in the other day and they found that the valve cover gasket is leaking and the rocker cover gasket. So they are in the process of replacing them both. I ended up putting a total of 2 quarts of oil in over about 2500 miles and it just didn't seem right.
Old Oct 12, 2004 | 10:53 PM
Jonesey's Avatar
My previous Gen II CTD also had a leaking valve cover gasket when brand new. It leaked exactly like yours johnsole. I would have sworn it was the rear main seal leaking. It's a good thing that I didn't bet the farm.
blackram2500
Apr 29, 2010 04:36 PM
mr T
Jul 27, 2006 11:50 PM
GlennRMK
Dec 12, 2005 04:28 PM
bulabula
Dec 15, 2003 11:47 AM
DF5152
Sep 22, 2003 02:46 PM
