First leak!
Old Nov 18, 2003 | 04:08 PM
Stevenc's Avatar
First leak!
I was installing the Putco nerf bars this weekend and notice some red fluid on 2 lines that ran from the engine to the trans. It might just be on one line but was hard to tell. Hopefully just a fitting loose. Boy I have taking it to the dealer already! :-[
Old Nov 19, 2003 | 07:21 AM
beemergofast's Avatar
Re:First leak!
My 03 with the 48re is leaving a nice little puddle of "red" fluid in my garage or wherever I stop after running for awile. I crawled under the truck to take a look and the bottom of the transmission an is coated with fluid. I also have a small oil leak that's coming from the drivers side of the engine....maybe coming from the breather. Either way, a new truck shouldn't be leaving a mark. I'll be taking it to the ******* tomorrow. Good luck.
Old Jun 18, 2004 | 12:43 AM
ramm4401's Avatar
My 03 just started leaking the red stuff 2 wks ago seems to be coming from the front of the tranny under the ring gear inspection plate--is this warranted?
Old Jun 18, 2004 | 06:00 AM
kry226's Avatar
There was a tranny cooler line recall put out a few months ago. Check to see if your trucks are involved.
Old Jun 18, 2004 | 07:02 AM
nonford's Avatar
Yep. There is a recall on these. Mine had 600 miles on it and just started to come out of the hose where the crimp was. The recall states that the tranny hose is not crimped correctly. Must be removed and crimped with a new attachment. Recall was issued in March 04, I beileve.
Old Jun 18, 2004 | 11:05 AM
SuperGewl's Avatar
Re: Re:First leak!
Leaving a mark
Must be a Male truck
You need to train that DAWG better
Old Jun 21, 2004 | 08:40 PM
ramm4401's Avatar
Went to the dealer today --about 5 hours later service tech. called me and said the 48re had to come out --he thinks the pump is leaking Mind you all this truck has 5200 miles on it and already had the recall performed and its not leaking on the right side of the motor lie some of the other members---it is coming from the ring gear inspection plate only--anyone else?
Old Jun 30, 2004 | 02:53 PM
FrankB's Avatar
Diff leak
Well I picked up my new 04.5 last Thursday and yesterday I noticed a small leak coming from the filler cap on the diff. My dealer says the filler plug is cross threaded and a new cover plate is on order.
It had less than 400 miles on it....... Built 5/12/04
Check your diff filler plug.
cheers f
Old Jun 30, 2004 | 09:18 PM
Mark Thomas's Avatar
transfercase leak for me, goin in thursday afternoon!
zig100
Mar 18, 2010 03:39 PM
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
