FIRST CEL ever...P 0249
Administrator/Jarhead
Evenin, DTR.... my first CEL in over 4 years...
P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
Truck is running good, I might have noticed my battery volts a little high after the CEL came on, but that could be my imagination...
I'm gonna go out and look at grounds, connections, ect...any other advice?
TIA!
mad
TIA!
mad
Just heard several guys with the same or similar code ( 1/2/3 injector , 4/5/6 injectors, ect ) . Just make sure there's no corrosion and that they are seated well. Next step would be to pull the valve cover and look for a chaffed wire. IIRC, the wires go thru the valve cover gasket, and there have been several known to rub thru.
Sounds like a winner.
With the way my week has been going, I would not be suprised if the truck threw a pistion while idleing, the OL left me, and I was struck by lightning after being in a plane wreck.
Thanks for the advice.
Sooo... Yesterday morning, jump in the truck... CEL is gone. Wednesday night, I checked a few connections, tightened my ground cables on my battery... everything looks good...
Ya know what I was thinkin...
I did turn my edge to 1 and my MP-8 all the way down, then this happened... I turned it back up.... it went away...???
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
gerry
May 13, 2007 03:09 PM
