fca / fuel rail pressure sensor
Old Mar 26, 2012 | 04:53 AM
steve2216's Avatar
i have a 2004 ram 2500 i am replacing the fca and rail pressure sensor are there any precautions or tips you can help me out with, do i have to relieve fuel pressure inthe system before i change these parts. thanks in advance
Old Mar 26, 2012 | 05:51 AM
DodgeRam24V's Avatar
no, a lot of people have difficulty getting the screws out.
use a 1/4" ratchet with a 1/4" deep scocket with the correct torx bit to crack them loose, be sure the "CORRECT" bit is all the way in the screw before attempting to loosen, tap it in.
Old Mar 26, 2012 | 09:33 AM
jhenson's Avatar
Lots of recent posts about the 3 Torx screws on the FCA. Madhat (admin) says he used some small bar stock (I believe it was) to tap the sides of the screws to help loosen up the loc-tite on the threads.
Rail pressure sensor......self-explanatory. Unscrew old sensor, screw in new sensor and plug in wiring harness.
Old Mar 26, 2012 | 01:46 PM
steve2216's Avatar
ordered the fca and a new fuel rail from genos came with pressure sensor and fuel limit is it a pain to change the rail out thanks again
Old Mar 26, 2012 | 07:00 PM
carl48's Avatar
no but it is easer just to change the sensor.
Old Mar 27, 2012 | 03:45 AM
it would probably take a half hour tops to change the rail, a couple minutes to change the sensor.
Old Mar 27, 2012 | 11:09 AM
06RAM2500's Avatar
Be sure to use brake parts cleaner and douse around the sensor and the fuel control. The less dirt contamination, the better.
Old Mar 28, 2012 | 04:37 AM
steve2216's Avatar
replaced the fca truck started but ran a little rough then it threw code p0088 im going to change the fuel pressure sensor see if that works do i have to relieve the fuel pressure when i swap this out if so how would i go about doing that. Thanks sorry for all the questions just cant afford to pay the mechanic any more
Old Mar 28, 2012 | 07:46 PM
no worries, no pressure is held in the system.
Old Mar 29, 2012 | 02:36 PM
steve2216's Avatar
changed all parts still get p0088 code high rail pressure had mechanic friend over seems to think it is a bad injector when it started had a loud knocking we cracked open injector #5 fuel line and it quieted down so i guess the next step is replacing the injector
Old Mar 29, 2012 | 04:55 PM
do you know what the rail pressure is?
it should be 5000# at low idle
Old Mar 30, 2012 | 01:55 PM
steve2216's Avatar
no the scanner he had could not read the fuel pressure
Old Mar 30, 2012 | 06:47 PM
i went to a friends shop, it took him 2 minutes to get his latest and greatest Snap On scanner to read mine.
i put in a gauge after that.
Old Oct 29, 2015 | 05:19 PM
Soarer's Avatar
Did you ever get your p0088 code fixed? I'm having the same problem. Interested to hear what the problem turned out to be and how you fixed it.
Old Oct 30, 2015 | 05:59 AM
Steve-l's Avatar
Here is another example of poor troubleshooting and a lesson to be learned. Shot gunning parts is only good for the parts vendors
5.9Excursion
55
Feb 26, 2020 09:55 PM
Old Smoky
0
Aug 10, 2011 02:53 PM
dodgediesel
Nov 25, 2010 07:40 PM
moparman13045
67
Oct 29, 2007 09:29 PM
draskobnsf
17
May 29, 2007 08:29 PM
