cummins FCA vs Dmax FCA
ok, i know the cummins FCA can be modified but i havent had the cajones to chop it up yet.....but my main question is....
does the Dmax FCA flow more fuel than the one for the cummins? I know i heard the Dmax one doesnt like extra input pressure so could you make a hybrid and change out the moving sleeve from ours with the triangle cut in it for the sleeve from the Dmax or just replace the whole thing?
I know this is outta the blue but my wheels are turnin and i am always lookin for somethin new
adam
adam
I know exactly what you are talking about. I was wondering the same thing. they have a different name for it in the duramax world, but I was thinking about modding the one in my lb7 chevy, because of what you guys were doing with yours. It would be interesting to do a side by side comparison.
Here is the only modification to an fca that i've heard of..
http://relentlessdiesel.com/forum/viewtopic.php?t=19
the d-max fca will flow no more than a cummins, but the cummins can handle much more input pressure than a d-max. dont know why but thats the case. the d-max pump it self is supposed to flow more than the cummins though.
If you take your time and follow the instructions in the thread it will go fine the only trouble anyone has had is not getting the valve smooth enough before reinstalling it and it was a little sticky causing spike in Idleing RPM's once they took them back apart and cleaned them up and polished them like they should have been done in the first place they were fine. I have had no trouble with mine its been on for a month or so.
The end cap comin out was my fault to some how I am sure.
LLY's are not as bad; you can run up to ~15psi lift pump pressure with them.
Theres no point running more than 10psi though, IMO. As long as you are not dragging the fuel supply into vacuum at WOT, having more lift pump supply pressure isnt going to help much. Just my oppinion....
ben
Please tell me why you know this to be a fact. I really want to know
because the FICM/EDU (especially on LB7's) has fuel running through it to keep it cool and doesnt like much more than 10psi of pre-CP3 fue pressure.
ben
ben
But this can be used at least on a LB7 to our advantage!
Can you say 27kpsi!You are correct about the FICM being the problem not the FCA (Pressure regulator in the Dmax world). The Cummins uses a Bosch ECM which does not need a FICM like the Delphi unit used in 01-05 Dmaxs. 06 Dmaxs do not use a FICM either and could really care less about input pressure from a lift pump.
