Engine revs up while at idle
Old Jan 21, 2013 | 12:37 PM
Kurran's Avatar
Hello,
I have on '05 3500 6 speed with an Adrinaline on it (right around 2+ years). With in the past 2-3 months I have noticed that my truck with randomly rev up from 7-800 rpms to like 1600rpms then right back down to 7-800 rpms. It's like somebody revving it to show off how loud it is but nobody is in it. I called Qaudzilla to see if it could be something with my Adrinaline all the sudden acting up, but they said no. Does anyone know what might be causing this???
Old Jan 21, 2013 | 01:26 PM
papaduck's Avatar
Might be a small leak in oil from the intake side of the turbo is causing the increased RPM. More than likely it is electrical such as the TPS.
Old Jan 21, 2013 | 03:12 PM
Kurran's Avatar
I haven't noticed any sort of oil leak. Is there any way to check the TPS to see if it is going out?
Old Jan 21, 2013 | 03:23 PM
crazybryan's Avatar
how cold was it outside, I had mine kick into high idle while up in the mountains this winter and was told it was due because of the temp. outside
Old Jan 21, 2013 | 05:24 PM
papaduck's Avatar
Most high idle is 1000 RPM. Kurran's is temporarly ging to 1600 tand then back down.
I am not sure how to check the TPS. But you can take the boot off between the turbo and intercooler and see if there is any traces of oil in it. If it is dry then you have eliminated that possibe problem.
Old Jan 21, 2013 | 07:31 PM
Kurran's Avatar
Ok I will remove the boot tomorrow and check that out.
Yeah the truck isn't idling up because it's cold, in fact ever since I have put the adrenaline on it doesn't idle up by itself when it's cold any more Not to happy about that, but let it idle 10 or more minutes on cold mornings before driving anyway.
Old Jan 22, 2013 | 08:47 AM
jhenson's Avatar
f....c...a
Replace it and drive worry free. Ask me how I know.
Old Jan 22, 2013 | 12:11 PM
Kurran's Avatar
Yeah latlely I have been thinking maybe it wasn't the best idea to go with the adrenaline. I was drawn in by the gauges in the monitor and the fact you could make your own tunes, but no matter what power seems to below par. A fellow welder at work just put a smarty jr on and said he can break the wheels loose in 4th and 5th gears! I consider that pretty impressive considering all the weight we carry on our rigs. I decently can't do that with the adrenaline
Old Jan 22, 2013 | 03:23 PM
jhenson's Avatar
Originally Posted by jhenson
f....c...a
In case of any confusion....FCA is the fuel control actuator on the back of the CP3. When it starts failing a number of things can happen.....one of them being the engine revving up on it's own from an idle.....it sends a faulty pressure signal to the ECM calling for more fuel when it's not needed.
Old Jan 23, 2013 | 06:47 AM
Kurran's Avatar
Yep that defently cleared up the confusion. I thought you were say adrenaline had messed up something on your truck. Still though I can't seem to get what I want out of mine. I need to make a post on the other section about it
Old Jan 23, 2013 | 07:58 PM
Kurran's Avatar
f....c...a
So I never asked, how do you know??
Also, when the F C A is going out will it cause a drop in fuel mileage?
tinknocker827
13
Dec 4, 2013 06:26 PM
ataboy9026
Apr 25, 2013 08:26 AM
spitzair
Jul 20, 2010 08:43 PM
Ahousaht Diesel
Oct 17, 2007 06:42 PM
