Transmission Shifts or Engine Revs w/o Gas
Old Oct 14, 2007 | 06:37 PM
Ahousaht Diesel's Avatar
My 1996 2500 4wd long box is a stock unit. My current problem is: the transmission seems to move in and out of gear at the same speed of about 70km/hr, even though I have not applied gas or let up. I am wondering if it is a transmission, engine or computer problem?
Old Oct 14, 2007 | 07:14 PM
MikeR's Avatar
So your saying while you are holding the throttle steady, and cruising at a steady speed in 4th gear, then you see the tach going up and down a couple hundred rpm?
That's a "dirty" signal going from the TPS to the computer, and it's causing the torque converter to hunt in and out of lockup.
Nowadays, usually you can install a signal filter and it will go away. But on the rare occasion you'll have to replace the TPS and add the signal filter.
I take it you're in Canada? Call DTT = Diesel Transmission Technology, they're in Abbotsford, they'll sell you the signal filter.
Old Oct 16, 2007 | 09:27 PM
ajs1995's Avatar
ok dont mean to steal your thread but i have a ? of the same sort my truck will occasionly do that in 3rd and 4th gear once i have lock up. if i ease into it it wont slip but if i give it more throttle it will slip pretty bad. i originnaly thought that the tranny was going but it doesnt slip sometimes. also when i first start it , it will roll forward ifi have it in reverse, same as if i but it in drive it can rol backwards. do yal have any ideas also takes quite a bit of throttle to reach 60
Old Oct 17, 2007 | 07:55 AM
Thanks. I will email DTT for a signal filter. I am new to the diesel truck and am wondering if you have any suggestions on a good service manual for the Dodge 2500 1996 auto 4wd long bock?
Old Oct 17, 2007 | 10:34 AM
infidel's Avatar
Try adjusting the TPS before you buy anything.
Instructions> http://dodgeram.org/tech/transmissio...TPS_adjust.htm
I've messed around with filters, isolating wires and cleaning the TPS with no long term results. Sometimes you just have to break down and buy a new TPS. Available though most autoparts, no need to get ripped off by the dealer.
Old Oct 17, 2007 | 06:42 PM
ajs1995's Avatar
alright thanks ill try doing that
Kurran
Jan 23, 2013 07:58 PM
spitzair
Jul 20, 2010 08:43 PM
cappykd
Jun 23, 2008 04:45 PM
bigbaddiesel
Nov 23, 2002 02:33 PM
