electric ticking sound before starting
Old Oct 21, 2007 | 11:50 AM
quick1300r's Avatar
04.5 HO , puzzeled to what it is , lift pump ? it does not stop after the grid heater dash light goes off, and will continue ticking with the key on until the engine is started,Thanks.
Old Oct 21, 2007 | 09:19 PM
CG98x's Avatar
The injectors will cycle and make a clicking sound before you start it.Thats what I'd suspect.
Old Oct 21, 2007 | 09:24 PM
no_6_oh_no's Avatar
Injectors 1 & 6 cycle to bleed off any pressure in the system. That will continue until the ECU sees pressure from the CP-3.
Old Oct 22, 2007 | 07:19 AM
nooska's Avatar
Is this bleed down, CP3 pressure thing the reason for the very slight delay in the engine firing after you turn the key to the start position??
Old Oct 22, 2007 | 08:56 AM
FMB's Avatar
FMB
Bleeds off pressure to where, into the cylinders?
Old Oct 22, 2007 | 11:42 AM
wreedCTD's Avatar
I think it is the grid heater continuing to cycle to harm the intake air. BUt i could be wrong.
Old Oct 22, 2007 | 06:57 PM
quick1300r's Avatar
clicking does not sound like its comming from the grid heater intake area, I left the key on to see if it stopped and after about 45 seconds it stopped.
Old Oct 22, 2007 | 10:50 PM
no_6_oh_no's Avatar
Into the injector fuel return circuit.
Old Oct 22, 2007 | 10:53 PM
no_6_oh_no's Avatar
Not really. The pressure is bled out of the rail so the CP-3 can build start pressure faster at just starter speed, that and synching the cam sensor and crank sensor to set the injection timing.
1985cucv
Apr 11, 2010 10:42 AM
bws
Nov 27, 2005 03:18 PM
1tuff3500
Sep 7, 2005 11:12 PM
doodah
Jan 28, 2005 03:48 PM
autodealer
Dec 4, 2002 04:46 PM
