electric ticking sound before starting
04.5 HO , puzzeled to what it is , lift pump ? it does not stop after the grid heater dash light goes off, and will continue ticking with the key on until the engine is started,Thanks.
The injectors will cycle and make a clicking sound before you start it.Thats what I'd suspect.
Injectors 1 & 6 cycle to bleed off any pressure in the system. That will continue until the ECU sees pressure from the CP-3.
Is this bleed down, CP3 pressure thing the reason for the very slight delay in the engine firing after you turn the key to the start position??
Originally Posted by no_6_oh_no
(Post 1751640)
I think it is the grid heater continuing to cycle to harm the intake air. BUt i could be wrong.
clicking does not sound like its comming from the grid heater intake area, I left the key on to see if it stopped and after about 45 seconds it stopped.
Originally Posted by FMB
(Post 1752139)
Bleeds off pressure to where, into the cylinders?
Into the injector fuel return circuit. :cool: |
Originally Posted by nooska
(Post 1752036)
