Difference in 03 and 04.5 turbos?
Old Jan 12, 2009 | 12:52 PM
GLHS's Avatar
Is the only difference the exhaust elbow or are the internals different too?
If so, how much?
What size are the wheels and turbine housings?
Will an elbow of an 04.5 work on an 03?
Can the entire turbo be swapped?
Thanks
Old Jan 12, 2009 | 02:35 PM
ratsun's Avatar
No
Dont know
Dont know
Yes
Yes
Cant help with the specs but I have read 100-150* difference in temps.
Havent finished my swap so I cant confirm this just yet.
Old Jan 12, 2009 | 03:38 PM
rip 112's Avatar
he 341 (03-04 305/555 motor) 54/58/9cm
he 351 (04.5-07 325/600/610 motor) 60/60/9cm
The he351 has an electronically controlled wastegate so you won't be able to swap them. The he351 will bolt right up to an 03/04 truck with substantial gains.
Old Jan 12, 2009 | 05:36 PM
GLHS's Avatar
[QUOTE=rip 112;2347270]he 341 (03-04 305/555 motor) 54/58/9cm
The he351 has an electronically controlled wastegate so you won't be able to swap them. The he351 will bolt right up to an 03/04 truck with substantial gains.[/QOUTE/]
Which is it, substantial gains or can't swap them?
Do you mean I need to swap the wastegate?
Old Jan 12, 2009 | 05:48 PM
DENVERDODGE04's Avatar
he means you cant put the 03 on the 04.5 but you can put the 04.5 on the 03, it is a nice cheap upgrade.
Old Jan 12, 2009 | 06:32 PM
GLHS's Avatar
OK.
So what to do with electronic wastegate?
It will function ok without?
Old Jan 12, 2009 | 08:35 PM
You will have to plug the hole where the electronic wastegate controler is and drill and tap the housing for an adjustable boost elbow. i swear someone on here said that GENOS garage sold a kit that just went into the hole for the electronic part and was threaded for a adjustable elbow. you might have better luck putting this in the HIGH Performance section, maybe get some more answers.
Old Jan 12, 2009 | 09:22 PM
Nate-03 D's Avatar
What could someone expect to see boost wise out of the 04.5 turbo?
Old Jan 13, 2009 | 10:45 AM
soulezoo's Avatar
DTR 1st Sergeant
With an otherwise stock motor (no cam, no head porting for instance) and aggressive programming, about 40psi. Less fueling would be less psi.
Old Jan 13, 2009 | 11:42 AM
AH64ID's Avatar
I would like to know more about this... TST sells a kit that uses boost from the intake.
I would set the WG to not exceed 35psi. With stock fueling and the WG off I have seen over 55psi of drive pressure at 33psi of boost. The limit on stock springs is 60psi.. so make the WG operational and set it to be fully open at 35psi. (With the WG on the DP may spike to 45 but settles at 38-40).
I don't even want to know what the drive pressures would be at 40psi. I am guessing over 80... That's way to high.. The stock turbo really needs a WG to be operational.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
jrs_dodge_diesel
13
Dec 22, 2003 09:50 PM
1320
30
May 31, 2003 01:01 AM
