Connecting Rod pictures
A while back I saw a picture of the connecting rods side by side of the Cummins, PSD, and D-Max. It was either here or on Turbo Diesel Register. Now that I would like to use it again I can't find it. Can someone be of help?<br><br>BTW I ordered on Feb 13 and my truck showed up at the dealer on March 18. I'll pick it up on Thursday. Not too bad a wait. <br><br>Thanks for your help and suggestions.
Re:Connecting Rod pictures
[quote author=FiverBob link=board=20;threadid=12491;start=0#118170 date=1048122861]<br>And - - - - - ??? ???<br><br>Which one is which?<br><br>[/quote]<br><br>The one that says ford is ford<br>the one that says dodge is dodge<br>the other one is a yugo<br>Does that clairfy it for you NeedsglassesBob?
[quote author=Luke S link=board=20;threadid=12491;start=0#118114 date=1048113703]<br>I remember the pic, but the pic of the Chevy rod was off an old 6.5 and not a Dmax :
<br>[/quote]<br><br>Does anyone know how the Dmax compares to the 6.5, connecting-rod-wise?<br><br>How bout the new Ford to it's predecessor?<br><br>I'm thinking they probably didn't change much.<br><br>Cummins still has them both by a landslide.<br><br><br>phox
The smaller connecting rods in the Ford and Chevy are inherent in the design of a V-8 configuration. The motor is shorter with 4 crankshaft connecting rod journals sharing space for two connecting rods each. The inline six crankshaft simply has the room for the larger connecting rods because each journal has only one connecting rod and the engine is longer. As long as Ford and GM continues to use the V block they will always have the smaller rods. One of the reasons the really big diesels are inline designs. Hope that makes sense.
Spots, you little smart alec - - I'm gonna have to come down there and blow some rust on you.
<br><br>Sorry guys, I didn't stare at that little blue tag close enough - - I was just enthrawled with the difference in the sizes and could never believe these all came out of similar size diesel engines. They did, right? ??? ??? Amazing how much larger the Cummins is than the others. Hey, I like my truck even more now. Yep, I do.
<br><br>Now, if I could only find my driving glasses - - found the reading ones, but man, where are those driving ones? Oh well, I'm in Florida - - don't really need them here - - might as well join all the other old goats who can't see the road either.<br><br>BlindAsBatAndDrivinInFloridaBob
[quote author=bneaves link=board=20;threadid=12491;start=0#118928 date=1048291153]<br>
I hope to goodness that is not the timing gear on the front of that crank!!!!!! My Schwinn bicycle sprocket was thicker than that!!!<br>[/quote]<br><br>No its tone ring or crank trigger for the tack and ECM/PCM.<br><br>The Cummins rods are indeed very strong, but when one looks at the loads they have to handle they are just marginally stronger than the PSD and Chevy.<br>The Cummins piston is one heavy chuck of metal and the rod needed to deal with that inertia will always be large. Two things you notice when you have one in your hand is the bearing surface area on both ends of the rod. Very large.<br>The crankshaft is heavy as well, but it has to hold up the 6 large rods and pistons swinging around. <br><br>Don~<br><br>
Guest
Posts: n/a
I thought the Cummins rods were a lot stronger than the PSD and Chevy's, even the 6.0L and the Duramax, because the Cummins rods are cast in one piece and the Ford/Chevy rods are powdered metal poured into a mold and flash-heated? I know that strength isn't all about how big it is, but how it's made. <br><br>ascraeus
GOTMEAT
May 24, 2004 02:37 AM
