Sponsored by:
Sponsored by: CARiD
Diesel Connecting Rod Pics (New).
Old Sep 13, 2004 | 02:26 PM
DieselDaze's Avatar
The new rods compared:
compared to older engine style rods:
Rich
Old Sep 13, 2004 | 02:28 PM
DieselDaze's Avatar
Looks like all three are becoming more competitive.
Rich
Old Sep 13, 2004 | 03:32 PM
bulabula's Avatar
I dunno, looks like two haven't changed to me. Adding the pistons is a nice touch.
Old Sep 13, 2004 | 05:27 PM
Considering the smaller piston, the Ford looks pretty good to me. The Chevy definitely looks weak in comparison, but not near as puny at that old 6.5 rod.
Old Sep 13, 2004 | 06:00 PM
2broke2smoke's Avatar
hmmmmmm ....
what are the rods made out of i wonder ...
forged
powdered metal?
Old Sep 13, 2004 | 06:52 PM
BigBlue's Avatar
The dodge rod seems to have lost some mass.
Old Sep 13, 2004 | 07:51 PM
Crimedog's Avatar
You can tell the Cummins is still thicker, though. I love that picture, I'm printing it off and showing it to a buddy who's hopped up on P Strokes
Old Sep 13, 2004 | 08:20 PM
graphitecumnz's Avatar
the Cummins rod has definitely lost some mass..... funny how much the new p-joke looks like a smaller version of a Cummins rod.
Old Sep 14, 2004 | 01:37 PM
nickleinonen's Avatar
the dmax piston looks better than the pos[d] around the skirt, but the cummins looks best with the solid aluminum skirt.... i gotta get me a set of them rods...
Old Sep 14, 2004 | 01:44 PM
SjLingenfelter's Avatar
Yea ford finally went with the side bolt rod instead of teh top bolt rod. Found out that side bolt rods are lasting longer for some reason.
Old Sep 14, 2004 | 02:02 PM
RustyJC's Avatar
The angle cut on the rod cap enables a connecting rod that uses a large (relatively speaking) bearing journal to be removed through a smaller bore. In other words, it lets one remove the piston and rod as an assembly through the cylinder. It really isn't cut that way to gain additional strength.
Rusty
Old Sep 14, 2004 | 08:31 PM
I was told that they cut them that way to gain strength
Old Sep 15, 2004 | 07:36 AM
RustyJC's Avatar
They cut them that way so they can get them out of the engine. The angle cut gets the bosses required for the rod cap fasteners out of the way. If they didn't angle cut them, the engine designer would have to specify smaller crank journals - from that aspect, the angle cut allows them to build a stronger bottom end.
Compare the measurement across the rods with the caps removed to the piston diameters in the first picture. The big end of the connecting rod (less the rod cap) has to come through a hole that's the nominal diameter of each respective piston. Just eyeballing it (recognizing that I'm an old man and half blind), the Ford 6.0 appears to have a smaller cylinder bore than the Duramax, but the angle cut connecting rod allows the 6.0 to have larger crankshaft rod journal diameters than the Duramax.
Rusty
Old Sep 15, 2004 | 08:50 AM
CTD NUT's Avatar
I like how the wrist pin bores are huge on the CTD compared to the others and even with the larger stroke of the CTD that extra rod length STILL gives a better rod ratio. The ONLY downside is that you can tell that the piston and rod combo on the CTD are much heavier than than the others - not good for high rpm longevity - but who cares? I don't have to rev my CTD to the moon to spank a durascrap or slowerjoke
Old Sep 15, 2004 | 09:48 AM
Don M's Avatar
DTR Advertiser
The new rods are forged, but not from the traditional steel we are used to.
They weigh slightly less. 62 grams lighter. They are thicker than the older rods, but are not as wide. They are also stiffer. The cracked cap is nice. The fastener on the new rod is weaker, but does not need to be as stout as the older bolt because of the cracked cap design.
The caps are angled for camshaft clearance and to facilitate the ease of removal during "in-frame" rebuilds in heavier trucks.
Don~
