code P 0243
Old Jan 10, 2008 | 10:04 PM
chy46's Avatar
code P 0243
There was a post a while back about a code P 0243 but no fix . I know its the wastegate soliniod malfuction ( spelling ) code but where is it and how can you do a FIX ?
Old Jan 10, 2008 | 11:32 PM
chy46's Avatar
dosn't anyone know about this one ???
Old Jan 11, 2008 | 06:02 AM
gmctd's Avatar
Would help if you'd post what type of truck you have - that's a generic DTC for any TC vehicle with a WG - I'm gonna hazard a WAGuess that you have a Dodge with a Cummins engine in it - so, check WG fuse - if ok disconnect the WG connector from the solenoid, see if pins are oxidized\corroded, any wires chafed\broken, up against exhaust manifold, turbo or pipe - if ok hook up a test lite between pin B and engine ground, turn on IGN = lite should lite - other pin A is PCM control - turn off IGN - connect the lite between pins A and B, turn on the IGN - in ~30 seconds the lite should lite very britely - if ok, the solenoid is bad - if not ok, check for broken wires in the harness - if wires ok, PCM is headed south for the winter
jlindsay
Jan 26, 2013 07:10 AM
d zul
Apr 22, 2010 04:15 AM
Floridacracker
Oct 12, 2008 11:02 AM
moparman13045
Jan 16, 2007 06:10 PM
CTD NUT
Apr 5, 2005 04:45 PM
