2 codes 0148 and 0243
Old Oct 11, 2008 | 11:52 AM
Floridacracker's Avatar
i have had these codes for some time now
i can not take my quad off or my truck has long starts and barly runs and has no power
i can't seem to get them to go away
please help me
Old Oct 11, 2008 | 01:38 PM
ngkefalides's Avatar
im getting the 0148 code as well and would like to know how to fix it. its saying that its high pressure common rail.
Old Oct 11, 2008 | 05:59 PM
can anyone help
Old Oct 11, 2008 | 06:09 PM
06 DIESEL's Avatar
The 243 code is from your sps62. Your truck came with a electronically controlled wastegate and now you do not have one. How did you disconect the wastegate? If you just put it in a bag and taped it out of the way this could be the problem. I got a boost controll resistor for mine so I would not have this problem. As for the 148 code this could be caused by your relief valve being blown. What kind of rail pressure do you run?
Old Oct 11, 2008 | 06:43 PM
my relief valve is pluged
the 0243 isn't the problem
my commander says i have 24,500+ w/ the engine off and the key on
i think it's the sensor just wanted to hear from some other people just to make sure i don't pay for somthing i don't need
Old Oct 11, 2008 | 09:09 PM
Brian Lent's Avatar
I was getting the 148 code and long starts. It started running weaker also. It was the connector tubes leaking. they won't start till the rail pressure hits 10,000 psi. The connector tubes were changed with my injectors 20k ago and they just backed out enough to give me trouble. Runs like a different truck now that they are re-torqued. That was three weeks and 1,800 miles ago and so far so good. No codes. I also have had the overboost code and I do have a resistor plugged in to the stock turbo harness. Only every now and then though.
Old Oct 12, 2008 | 11:02 AM
what do u mean by connector tubes (from the rail to the injectors)???
i only have long starts when my quad is unhooked
jlindsay
Jan 26, 2013 07:10 AM
d zul
Apr 22, 2010 04:15 AM
screamin01
Jan 22, 2008 05:48 PM
chy46
Jan 11, 2008 06:02 AM
moparman13045
Jan 16, 2007 06:10 PM
