wastegate selenoid code 0243 ?
Old Apr 19, 2010 | 08:38 PM
d zul's Avatar
My brother in laws truck is throwing a p0243 code. It is a bone stock 03 2500 6 speed. I think he may have a wire rubbing some place because for the last few weeks after letting his truck set for a few days he has to jump it off. Am I on to something here, and where is the first or most likley place to start looking? Also, where is the wastegate selonoid located?
Old Apr 19, 2010 | 10:16 PM
synner's Avatar
From what I can tell its located on the bottom of the turbo unit. My 05 is throwing the same code. I'll have to check for chaffed wires before replacing the solenoid.
Old Apr 20, 2010 | 03:38 AM
Dodgezilla's Avatar
An 03 truck doesn't have the wastegate solenoid. That's a strange one....
Old Apr 20, 2010 | 03:44 AM
madhat's Avatar
Administrator/Jarhead
Have him look at the wiring harness behind the AC compressor clutch, see if it's rubbing.
If that looks good, pull the battery terminals, clean them, and pull the engine ground. Clean that contact, feel the cable, make sure it's not really hard or stiff.
Old Apr 20, 2010 | 06:58 AM
d zul's Avatar
Thanks guys. I'll see what we come up with. He said it would run bad and didn't have the power it should when he got on the pedal. Sounds like a boost problem.
Old Apr 20, 2010 | 07:38 AM
d zul's Avatar
Dodgezilla is half right. My 03 dont have a selonid but my BIL's does, just to be shure the selonoid is on the underside of the turbo, it is about 2" long, round and has two wires coming iut of the end. Those wires seem to be rubbing on the sharp edge of the "selonoid" up above the wire loom. Need to wrap the bare spots with tape and pull the loom up a bit, and hope this fixes the problem. Thanks guys for the replies, I will keep you posted.
Old Apr 20, 2010 | 11:05 AM
Dodgezilla's Avatar
Dodge did not put the turbo with the solenoid (HE351) in these trucks until 04.5. I would venture to say that his is not a 2003. There should be a tag on the valve cover that states the HP rating. What does that say? 325HP or 325ISB?
Old Apr 20, 2010 | 12:10 PM
d zul's Avatar
I will check the tag when he gets home, pretty shure it's a 03 with 305hp, but will check the date of man to make shure. May not be the selonoid I was looking at. It is on the under side of the turbo on the pass. tire side with two wires coming out, round and about 1 1/2" to 2" long. Thanks Dodgezilla.
Old Apr 20, 2010 | 03:49 PM
Dodgezilla's Avatar
That is definitely describing the solenoid but an 03 would not have come with it. My early 04 has it but it's because I swapped turbos. Those wires aren't hooked to anything on my truck though....
Old Apr 21, 2010 | 01:16 PM
d zul's Avatar
Dodgezilla, you are right. Popped his hood and shure enough it is a 04.5. Had to give him a hard time for telling me it was a 03. Thanks once again for the help.
Old Apr 21, 2010 | 06:57 PM
Dodgezilla's Avatar
LOL. Well he still probably needs a new solenoid. Plenty of guys like me have swapped turbos and tossed their solenoids in the corner. You may want to place a "Wanted" ad for one here....
Old Apr 21, 2010 | 07:45 PM
d zul's Avatar
He came over tonight and we taped the wires up and got them off the solenoid. One was cut through pretty good. He is going to drive it to work tommorrow and see if it cleared up. May just see if anyone has one laying around. Can you reset the codes without taking it someplace?
Old Apr 22, 2010 | 04:15 AM
Dodgezilla's Avatar
If you have a code clearer you can.
I have a friend with the same problem on his 05 truck. He had to solder the wires back on properly to make his truck run right....
Floridacracker
Oct 12, 2008 11:02 AM
chy46
Jan 11, 2008 06:02 AM
moparman13045
Jan 16, 2007 06:10 PM
Korney
Jun 21, 2006 04:45 PM
matador
24
Aug 28, 2005 06:37 PM
