Clutch Squeel???
Clutch Squeel???
Noticed my clutch (g56 unit) is squeeling a bit lately. Seems to be worst when letting of the throttle on decel. Goes away when i push in clutch, doesn't do it at a stop/idle. Throwout bearing? or input bearings?
Had the tranny fluid changed not to long ago, wonder if they didn't overfill it or put wrong fluid in....any ideas
Thanks, RB
Thanks, RB
Checked tranny fluid and it is right at the bottom of fill port. i always put an extra 1/2 qt or so but level looks ok. noticed on my receipt that the shop put in a castrol mulit-vehicle atf, not the the redline C+ we agreed on that is atf+4 approved. Could this have something to do with squeeling sound?
what would make crankshaft bushing/bearing to input shaft go bad?
only 69k miles on clock, stock motor.
VikingDiesel
Aug 1, 2006 03:58 PM
