Front Brake Squeel
Old Aug 28, 2004 | 02:21 AM
SuperGewl's Avatar
Front Brake Squeel
Has anybody come up with a fix yet
I have installed 2 sets of aftermarket and 1 set of DC Value line disk pads. I have even had the dealer turn the rotors and guess what SQUEEL
Oh, yeah I also have a clunk when you backup and turn the wheel and put your foot on the brakes. The dealer is ordering a caliper (1) for the right front. IMO I think the one on the left front needs replacing also.
Any HELP would be nice
Old Aug 28, 2004 | 08:23 AM
Hounddog's Avatar
The VALUE line/aftermarket stuff is the cause.Also make sure rotors are swirl finished.
Old Aug 28, 2004 | 09:33 PM
SuperGewl's Avatar
I just ordered the OEM ($115.00) pads and will replace them Tuesday. If the SQUEEL goes away I will let you know. If it doesn't then I'm going to make DC replace the drivers side caliper and refund me for the rotor turning and possibly the pads themself due to a BAD design of the system.
Old Aug 29, 2004 | 11:06 AM
Hounddog's Avatar
The brake shims,caliper slides lubed and rotor finish is VERY important to keep squeal from happening to start with.
Old Aug 30, 2004 | 02:51 AM
SuperGewl's Avatar
All done by me with ever loving care and I had the dealer due it agian when the turned the rotors
Guess what, they still SQUEEL
Old Aug 30, 2004 | 05:09 AM
zulusafari's Avatar
I used to get a product from AutoZone that was something like: "Disc Brake Quiet", came in pouches. You had to spread this red paste/liquid on the back of the pads, let it dry for a while, then reinstall. Took care of all brake squeels on several cars I have had (89 Tempo, 92 Spirit ex.) but I never tried it on a truck. Might work, and was very cheap! Like maybe a buck a pouch (1 per wheel)?
Just past experience.
Old Aug 30, 2004 | 06:24 AM
Hounddog's Avatar
That product and several others are used on most brake jobs.Dosen't seem like squeal has been a problem on these trucks.I haven't had a brake squeal/squeak on anything in years.Wonder whats going on with this truck.Brakes also need a break in time.To hot too soon and pads/rotors glaze right over.
Old Aug 30, 2004 | 03:58 PM
HorseHauler's Avatar
i cant remember off the top of my head the exact name something i havent heard before like a kariko joint or somthing, thats probably not even close at all
but ill find out tmw. my friend test drove a truck today and said the brakes sounded squealy and they found something else that wasnt the brakes
Old Aug 30, 2004 | 04:55 PM
Turbo Deeezle's Avatar
From my experience if one caliper needs to be replaced........ you have to replace both. Tell the dealer to cough it up.
Old Sep 4, 2004 | 12:13 AM
SuperGewl's Avatar
Replaced front brake pads with OEM $115 pads, guess what
SQUEEL all gone
I will say that the OEM pads were made different than the Value and the TheroQuiet pads I had purchased.
The OEM pads had a different backing on them that was covered up and I had to remove the cover paper, the metal backs of the pads were also cut different, they had beveled edges vice the normal square cut pieces of metal
I still have th clunking from the right front caliper when I backup and hit the brakes to stop. I'm still waiting for the dealer to get the caliper to replace it
We will see what happens
whereswaldo250
Nov 6, 2006 08:32 PM
kutch
Oct 10, 2006 04:45 PM
ixx
Aug 4, 2006 09:21 AM
VikingDiesel
Aug 1, 2006 03:58 PM
A-Poc
Jul 30, 2006 10:55 PM
