belt squeel at shut down
Old Oct 10, 2006 | 10:40 AM
kutch's Avatar
Question belt squeel at shut down
The previous owner changed out the serpintine belt at 40K. He stated that the quick "chirp" at shut down is due to the super high compression of the motor stopping faster than the accessories....Therefore the belt chrip...
True or false?
-Kutch
Old Oct 10, 2006 | 10:52 AM
carcrz's Avatar
True. It's hard to slow down all of that power. It just wants to keep going.
Old Oct 10, 2006 | 11:12 AM
bigredBCS's Avatar
there is no way to stop it, i know if you turn the air off before turning the truck off its not as loud, but every diesel i ahve ever been in brand new, old whatever, has done it
Old Oct 10, 2006 | 11:39 AM
billygoat02's Avatar
It's a beautiful sound in its own unique way. After while you won't even notice it. Big thing is just stay on top of the condition of the belt and when it starts getting bad replace it. This will keep it to a minimal level and keep it from driving you nuts. JMO.
Old Oct 10, 2006 | 01:58 PM
TXDRAM's Avatar
Chirp TSB
I believe there is a TSB on the chirping sound... check with your dealer for the repair:
TSB 09-004-06
Accessory Drive Belt Chirp At Shut Down
Symptom/Condition:
A chirping sound maybe heard coming from the accessory drive belt when the engine is
shut down.
Parts Required: Qty. Part No. Description
1 05183490AA Overrunning Clutch Pulley
Special Tools/Equipment Required:
8823 Generator Shaft Holder
Repair Procedure:
1. Disconnect and isolate both negative battery cables.
2. Remove the air cleaner box.
3. Loosen the accessory drive belt and disengage it from the generator.
4. Remove the generator.
5. Remove the drive pulley from the generator.
6. Install the new drive pulley, p/n 05183490AA, using toll number 8823 to hold the
generator shaft. Tighten the nut to 80 Nm (60 ft. lbs.)
7. Install the generator. Tighten the bolts to 41 Nm (30 ft. lbs.)
8. Install the accessory drive belt.
9. Install the air cleaner box.
10. Connect the negative battery cables.
No cost.
Old Oct 10, 2006 | 02:48 PM
CUM4X4MINS's Avatar
If I remember right the new 01/07 trucks will have the over driving pully already. But the noise doesn't bother me I kinda like it
Old Oct 10, 2006 | 03:29 PM
XLR8R's Avatar
Between the belt chirp, shutdown shake, and the dual-mass death rattle - people look at my beautiful truck like it's a pile.... I love my heap!
Old Oct 10, 2006 | 04:18 PM
CUM4X4MINS's Avatar
Ya I know right!
Old Oct 10, 2006 | 04:45 PM
NHdodgeman's Avatar
True or false?
-Kutch
True, completely normal as others have stated. If the chirp bothers you when its time to replace get a gatorbelt. Problem solved
ngrov
Mar 7, 2009 08:13 AM
dj_souvlaki
Jul 21, 2007 06:31 PM
cbrahs
14
Jun 7, 2007 10:42 AM
robwashu
16
Aug 10, 2006 08:09 AM
A-Poc
Jul 30, 2006 10:55 PM
