clean injectors
Old Feb 5, 2006 | 08:23 AM
mattsdiesel06's Avatar
clean injectors
is there any additive you can add to help clean the injectors on the ctd
Old Feb 5, 2006 | 11:07 AM
Hounddog's Avatar
SEAFOAM at most auto parts stores.They're other stuff there also.But SEAFOAM is kinda tried and true.Two cans of Seafoam to a tank and some Marvel Mystery oil in the fuel with it.
Old Feb 6, 2006 | 08:48 PM
gnarlykaw's Avatar
I use BG 248, it is designed for the electronic injectors.
Old Feb 7, 2006 | 01:08 AM
Syndicate's Avatar
My truck was starting to blow a fair amount of smoke in the mornings and Idle kinda rough till it warmed up unless I upped the rpm to just over 1000. I just added a half a bottle of Howe's Meaner Kleaner to a full tank and WOW!
I didnt know a diesel could run so smooth. Its up about 1.5mpg no more smoke or rough idle and it is so quit I can hardly tell its running with my stereo turned up. I am a big fan of the Meaner Kleaner!
Old Nov 10, 2008 | 08:10 AM
MotorCityMadman's Avatar
How long did you have to run it to make a difference?
Old Nov 10, 2008 | 09:32 AM
06RAM2500's Avatar
Seafoam has alcohol in it=really harsh on the CR injectors. You will notice a difference if they are gummed up.
Brian.B
Dec 10, 2012 02:14 PM
DU.DP.
Mar 18, 2009 12:03 AM
hungabunga
Apr 10, 2008 08:55 PM
dervolksfuhrer
Jan 30, 2008 06:05 PM
chumstone
Dec 20, 2006 08:54 PM
