how do i clean gel from injectors?
Old Apr 9, 2008 | 10:08 AM
hungabunga's Avatar
From: Canyon lake tx. just outside of New Braunfels
1st post..hope i'm doing it right....man do i need help....i have a ' 041/2, 2500....i topped off my tank at a shell station with their 20% blended diesel...it had been warm for a couple of weeks then a cold front blew in, the fuel gelled and formed a waxy substance and now my truck runs like a one legged dog...if i put a heating cable on the injector rail will it melt the wax.....will my block heater get my injectors hot enough to clear them?.......or should i just put it in the shop?...i found an additive made by power service to keep it from happining again called biodiesel anti gel...but it won't solve the problem i have now..........any help would be greatly appreciated....the codes showing are 3 injector codes 2 thru 5 and a p 2146, i don't know what it is.............thanks
Old Apr 10, 2008 | 08:55 PM
John_P's Avatar
hungabunga:
I have had this happen to me once and used a similar product as you described from a company by the name of "Racor". They supply alot of diesel fuel products and conditioners to the trucking industry. It worked real well, but it was on a 96' Dodge Cummins 5.9 12 valve engine which is somewhat different than your 2004.
Good luck!
John_P
Brian.B
Dec 10, 2012 02:14 PM
DU.DP.
Mar 18, 2009 12:03 AM
hungabunga
Apr 9, 2008 08:21 PM
shaft
15
Nov 19, 2003 08:33 PM
mitchkim
Oct 25, 2003 08:55 PM
