Check Gauges Light?
Old Jul 28, 2015 | 11:36 AM
Tarosean's Avatar
Check Gauges Light?
What sensors/conditions will trip the Check Gauges light?
I was driving my 07 diesel the other day and it came on.
Nothing appeared abnormal with the gauges or fluid levels.
Old Jul 28, 2015 | 02:11 PM
bobsallyh's Avatar
Well the volt gauge is well to the left. Even when the heater is on after a cold start mine doesn't go that far left. If the heater had shut off by when the picture was taken, I'd be checking a voltage issue at the battery and/or alternator for starters.
Old Jul 28, 2015 | 04:33 PM
Tarosean's Avatar
Well I got 12.03v at the Drivers side and 17.5v at the passenger side just after startup (100f outside)
With all lights on, A/C, it dropped to 11.69v on Drivers side with the passenger side still overcharging @ 17.5v.
So it appears I have a faulty charging system or ?????. Batteries are less than 6m old.. course at 17v one is probably fried now!
Old Jul 29, 2015 | 12:12 AM
Steve-l's Avatar
No, your assumption is incorrect. It means your two batteries have a faulty, resistive or corroded connection between them. There should be no difference in voltage between the two batteries ever.
Old Jul 29, 2015 | 10:27 AM
Tarosean's Avatar
Nailed it Steve. I had already pulled and cleaned the terminals even though they appeared clean. However upon further inspection, I was also getting the 17v in the crossover cable but not in my drivers side battery. I pulled the locking lug bolt off the drivers side cable and cleaned in between the surfaces. Both batteries show 14.5v now ("Cold" start @ 88F).
madhat
68
Oct 25, 2015 08:25 AM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
quantrill88
Dec 14, 2003 06:41 PM
