Boost question on an 06
Old Mar 5, 2007 | 05:02 PM
own1bigtruck's Avatar
Question Boost question on an 06
I installed my gauges this weekend and im concerned about the boost pressures im getting. When I stand on it all the way to 3K, I cant seem to get over 22-24. When just rolling down the road empty at 55 and 1500 rpm, its only reading about 4-6. Is this normal? Im running a stock turbo also. If this isnt normal, is there something in perticular that i need to investigate as to why my boost is low? The turbo spools up fine, it just doesnt seem to be showing it.
Old Mar 5, 2007 | 05:12 PM
MOJO1's Avatar
Thats normal.Mine with the BDDL on i only see 20 So i got a boos fooler coming from LARRY ELLIS i will see some boost then.
Old Mar 5, 2007 | 05:43 PM
What does this boost fooler do, i have heard it talked about a couple of times now
Old Mar 5, 2007 | 05:54 PM
$oC@l CTD's Avatar
You have an electronic wastegate on your truck's turbo. At around 30-32PSI, it automatically defuels the engine, drops your boost down in the low to mid 20s, then slowly lets it build back up. The boost fooler will allow you to see around 38 constant and spikes near the low to mid 40s. If you were to hit boost levels that high without a fooler, your truck would start throwing over boost codes and ultimately end up in limp mode. Hope that answered your question.
Old Mar 5, 2007 | 06:04 PM
Bswope's Avatar
Man with the TST turned off i can see 35-37lbs depending on how i run it! Turn the TST on and i can hit 40psi no problem, not that that is a good thing but i can hit it! I have the boost set to 38psi.
Old Mar 5, 2007 | 06:47 PM
EDR's Avatar
EDR
I'm new to DTR and I've come across the ads for the electronic boost foolers (Quadzilla, etc.) as well as the modified brass elbow with an adjustable set screw, and was wondering if they are both required to fool the system, or does the third generation CTD only need the electronic fooler?
Finally, who is Larry Ellis and why are you buying his fooler?
Thanks,
EDR
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
